Originally, I thought the Char-lynn torque generator was mounted backwards on this tractor:
It's mounted facing the correct way. The difference is, it has TWO NOSES.
Normal char-lynn units have a smaller diameter nose on the output end of the motor, like this:
Mine has the same tapered section on BOTH ends of the unit. I've never seen one like it.
What tractors would have had the aftermarket power steering up at the steering wheel like this?
