Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: How long will a Farmall A idle for on a full tank of gas?
gene bender
11-12-2012 06:15:05
You are going to run the tractor faster than idle to get the alt to put out more power. The pulley on the A isnt that big so to get the Alt running fast enough for its output makes running at idle wont work you need to see how fast the Alt needs to turn for its potential. Due to the crank pulley on the A you cannot attach a pulley there. Now how about running the Alt off the belt pulley as you can easy do that. You can get a Browning bushing on the splines and run as large a pully as needed for the alts output and use a 12v batt in the circut leaving the As system apart from the Alts circut now you wont need as much motor RPMs.
Copyright © 1997-2015 Yesterday's Tractor Co.
