TD-9 Serial / Suffix Question
labman98
Hello,
I'm looking at a international TD-9 Serial # TDCB24816T7BJ. I found that it is a 1946, but what does the TDCB and the T7BJ mean? I'm not able to find this info.
Thanks in advance!
TDCB means it is a diesel crawler. I can't tell you what the other stuff means bc it is crawler talk.
TDCB is the prefix letter code that simply meant it was TD-9. The suffix letter code T7BJ means it has the following special features:
Wide tread, heavy duty track roller shield, front PTO, cutaway sprocket, lighting or starting (delco-remy heavy duty)
