TractorLinks.com
Show Parts for Model:
Re: Super C Camshaft Gear
El Toro
11-11-2012 15:56:31
I would heat it in the oven. If that doesn't work you have to pull the cam and have it pressed on. Make sure you timed it correctly when installing the gear. I have a sketch somewhere on the computer. Hal
farmallday
11-11-2012 18:19:24
 Re: Super C Camshaft Gear in reply to El Toro, 11-11-2012 15:56:31
just put one on a C here this spring!! What you have to do is bake it in a pan of oil(i used vegy oil) I baked it at 450F four about four hours then when you put it on make shure you have the timing lined up and beat it home. I used a wood block and a sledge with smaller taps. I found that a hammer just would'nt do. The cam dose have some play back and forth that makes you think that you need to pull the cam, but you dont need to. They say that you need to bake it for a long time to evenly dispnse the heat?? It worked for me!!
