Topic: Super C Camshaft Gear
[Return to Forum]
| Author |
[Modern View]
| Smith1000
11-11-2012 10:39:18
199.192.211.205
Just pulled off the old camshaft gear. To install the new one, do I need to drill and tap the center to draw it down, or, if hot enough, will it slide on without force?
[Reply] [No Email] | |
| Owen Aaland
11-13-2012 23:55:38
216.47.35.197
Re: Super C Camshaft Gear in reply to Smith1000, 11-11-2012 10:39:18
| I had a tool made to install cam gears. You need an extra camshaft nut. Weld a 5/8 of 3/4 bolt to the nut being careful not to damage the threads. Use a lathe or carefully grind down the weld and nut until the gear will pass over the nut. Install your new tool on the camshaft and put the gear in the correct position. Use a piece of pipe or a bushing that will clear the tool and draw the gear on with a nut. |
| El Toro
11-12-2012 14:45:42
108.3.143.30
| I would do as Pete 23 suggested and pull the camshaft before you damage something. Drop the oil pan, oil pump, remove rockers, pushrods and push the tappets up into their bore. Then you can pull the cam. Have your local auto machine shop to press the new gear on. Separate each item you remove and mark where it was removed. Cardboard boxes are usually handy for this. Hal |
| pete 23
11-12-2012 10:59:01
74.32.238.2
| About three things here to be concerned about. First, if you have to tap it on you are putting some force on the oil pump drive gear, second, if it goes back far enough it will loosen the expansion plug behind the cam so then you can split tractor to replace it. Third, that engine has none or at most one cam shaft bushing so pulling the cam out is actually quite easy. No big worry about scratching the bushings when pulling out and back in. |
| Smith1000
11-12-2012 09:19:39
199.192.211.205
| I had it in the oven for 35 minutes on 450. That part worked fine. It was plenty hot/expanded, but that shaft has give in it and, unless the gear was completely loose going on, it is not going to go on all the way because the shaft retreats. It also has to mesh with the crank gear, which puts pressure on things.
I might just be able to tap the center of the shaft and draw it down. That might be a better option than pulling the shaft.
The key had shifted and I didn't realize it. I think that is when it moved throwing the timing off. The other thing is I did not pull the hydraulic pump gear. I will pull the pump off for the next go around. |
| Smith1000
11-12-2012 07:47:12
199.192.211.205
| | Didn"t work out. I got it on part of the way, but was off 1 tooth on the timing as I didn"t have it line up quite right. I already pulled it off. There is no way to get the cam gear fully on on the shaft this way because the camshaft recesses about a quarter of an inch when you tap on it. The gear bottoms out against the housing and it won"t fully go on. The cam teeth will line up with the crank teeth, but the camshaft is recessed and the shaft does not come out flush with the gear. I"ll have to pull the camshaft. It would probably run part way on, but it seems like it might be a problem eventually. |
| Smith100
11-12-2012 06:28:44
199.192.211.205
| Thanks. Got the new one in the oven right now. It is about 25 degrees out this morning, so this is a good morning to put it on. Sounds like it can be tapped on. I read though that if it is hit too hard, the plug could pop out on the back of the cam. I'll get it good and hot. |
| farmallday
11-12-2012 09:11:11
184.21.113.230
Re: Super C Camshaft Gear in reply to Smith100, 11-12-2012 06:28:44
| I know i was worried that i would have to pull the cam but i still dont think you should have to!! How long did you bake it?? I made the same mistake with the timing marks. |
| El Toro
11-11-2012 16:07:04
108.3.143.30
|  Here's the Super C's timing gear installation. Note the typing on the edge. Hal |
| El Toro
11-11-2012 15:56:31
108.3.143.30
| I would heat it in the oven. If that doesn't work you have to pull the cam and have it pressed on. Make sure you timed it correctly when installing the gear. I have a sketch somewhere on the computer. Hal |
| farmallday
11-11-2012 18:19:24
184.21.113.230
Re: Super C Camshaft Gear in reply to El Toro, 11-11-2012 15:56:31
| just put one on a C here this spring!! What you have to do is bake it in a pan of oil(i used vegy oil) I baked it at 450F four about four hours then when you put it on make shure you have the timing lined up and beat it home. I used a wood block and a sledge with smaller taps. I found that a hammer just would'nt do. The cam dose have some play back and forth that makes you think that you need to pull the cam, but you dont need to. They say that you need to bake it for a long time to evenly dispnse the heat?? It worked for me!! |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
