Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
H Trans Fluid Drain/Clean
WI Dave
11-11-2012 07:26:23
I finally got around to changing the trans fluid in my H. It took 4 hours to fill the 5 gal. bucket fron the rear drain, and I got about 1 gal. from the front drain plug, but had to scrape/pull the sludge out the whole time. The belt pulley drive is still off, and I can see there's still about an inch of sludge still in there. Should I put the plugs back in and dump a few gallons of diesel in it, let it sit a few days, then drain and flush with more diesel?
Zachary Hoyt
11-11-2012 08:29:06
 Re: H Trans Fluid Drain/Clean in reply to WI Dave, 11-11-2012 07:26:23
Diesel or kerosense and driving around slowly for a little while with no load is the remedy I have seen recommended to clean out sludge. Zach
rustred
11-11-2012 07:46:22
if it were mine i would dump in a 50/50 mix of hyd. oil and diesel and drive it around for awhile.diesel alone is not the best lubrication for differential or trans.
rustred
11-11-2012 07:53:21
 Re: H Trans Fluid Drain/Clean in reply to rustred, 11-11-2012 07:46:22
instead of reinstalling belt pulley off and on. just get a piece of 1/8 flat metal and fab. a cover for it with a couple bolts, even a 1/4 " plywood is good enough.just to keep the oil from splashing all over.
Copyright © 1997-2015 Yesterday's Tractor Co.
