TractorLinks.com
Show Parts for Model:
Re: super a pitman arm
Ol' Gimpy
11-10-2012 15:40:52
I"ve had to use the old reliable "Heat" method on more than one of them,they can be a @#$$@!V to remove any other way.If you are using it as a worker,you may be able to try to weld a nut on the casting,but to get out the old bolts will be a test of patience.They get "Mushroomed" over from being tightened over time,and impossible to get out as a result.As the guys said,may be a good time to renew the seals,check bearings/bushings,see if the retainer bolts for the two housing halves are tight,etc.
flopguns
11-10-2012 16:52:34
 Re: super a pitman arm in reply to Ol' Gimpy, 11-10-2012 15:40:52
hello, i could tap them out to a larger size, the two bolts are the ones close to the block and i am a nut when it comes to being orignal with the right ih dot bolts will get a puller and try heat thanks keith
