Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 300 Utility hydraulic questions
[Return to Forum]
300 dave
11-10-2012 10:36:29
74.32.160.84
Hi gang,
My 300 utility has a hydraulic problem, hoping someone can set me straight.
While running, it periodical makes a groaning noise
and squirts fluid out the mounting flange below my right knee; that is the flange for the lines to/from the pump. It is blowing fluid all over the console, battery etc. Fluid is whiteish and most likely needs changed out. What cause the pump to grain and pressureize the lines every minute or so?? Thank much in advance
d
[Reply]   [No Email]
350u
11-15-2012 05:17:46
98.19.39.176
Re: 300 Utility hydraulic questions in reply to LesWA, 11-10-2012 10:36:29
Yes the strainer is in the resivior and have to take the top off to remove it. It is very heavy an engine hoist works good to lift it off. I purchased the gasket from my IH dealer, if I remember right it wasn't too expensive. The "gasket in a tube" product works well too in applications like this. As far as the fluid spraying all over, the pipe is probably cracked at the mounting flange. They are brazed in from the factory, you may be able to "slobber" more on to seal it??? It was a little work and a lot of measuring, but I cut the flange off made a new one and welded it back on to the slightly shorter pipes.
  [Reply]  [No Email]
300 dave
11-12-2012 06:16:20
74.32.160.84
Re: 300 Utility hydraulic questions in reply to 300 dave, 11-10-2012 10:36:29
thanks to all again, Does the valve box have to be removed from the machine to get it all clean?
Where is the drain for the tank (under seat)?
Will the valve box from a 300 Row crop Fit on and work? Aside from the handles being a bit difficult to use. I have one on the bench.
  [Reply]  [No Email]
Janicholson
11-12-2012 15:00:03
96.24.99.126
Re: 300 Utility hydraulic questions in reply to 300 dave, 11-12-2012 06:16:20
The drain is on the right front bottom corner. it allows oil to run down the side and under. (I put a short length of pipe nipple in the hole quickly so as to keep mess to reasonable levels). I believe the valve will need to be taken off. The reservoir does not One screen to clean is in the reservoir. Jim
  [Reply]  [No Email]
300 dave
11-14-2012 12:41:37
50.48.49.84
Re: 300 Utility hydraulic questions in reply to Janicholson, 11-12-2012 15:00:03
HI and thanks again Had good weather today (35 outside)so, fluid is like heavy cream, about same color; just off white toward tan.
Got all disconnected and dripping out, FOund drain plug under cylinder mount. Valve is in shop ready to be hosed and fixed.
So questions are, 1)where is the screen in the resivoir that needs to be cleaned and how to get it out? 2)Why NOT pull the resivoir box ? It is a few bolts. The gasket could probably be made from the "in a tube" type stuff, temperatures allowing of course. Or is that overkill?
  [Reply]  [No Email]
jimb2
11-10-2012 12:20:58
174.114.182.155
Hi Dave,
To add to what others have said, clean the suction screen inside the reservoir under the seat.
JimB
  [Reply]  [No Email]
RPM1941
11-10-2012 11:24:13
173.23.76.185
I would deal with the contaminated fluid right away if you are in a cold area or tractor is outside in freezing or below temp. The water in the oil will freeze up and starve the pump, could damage it badly. It needs to be changed yearly, it will hold some in suspension ok but has chemicals to make it white when its past its limit.
  [Reply]  [No Email]
300 dave
11-10-2012 11:10:18
74.32.160.84
yes guys thank that was quick I did not finish lunch !
The water I will deal with in a week or so when I can get it under roof and heated for a couple days.
Beside draining, can I flush the lines with anything ? hot air blower? any thing in addition to just draining?
Jim, this pilot valve thing, will that be in the IT manual? Location? I would like to find it with out taking half the machine apart. Also, does that system pressurize every so often by itself automatic
or what? Why does it pressurize the system every minute or so. Is it compensating for lost holding pressure in the cylinder?
I use this machine for hauling wood (now) snow plowing and garden plowing. Just has the one cylinder.
I will be back in about 4 hours.
thanks again and WOW!
  [Reply]  [No Email]
Janicholson
11-10-2012 11:48:30
96.24.99.126
Re: 300 Utility hydraulic questions in reply to 300 dave, 11-10-2012 11:10:18
Look for the parts diagram in caseih.com on line parts catalog. The valve is in the cast iron block between the lever and the reservoir. The issue is that the valve is probably cycling due to contaminated fluid, and partially plugged up screen in the block. Put 300 in the first box. then select hydraulic system, then touch control, then hydraulic system flow control valve... near the bottom of that list. Jim
  [Reply]  [No Email]
IH fan
11-10-2012 10:53:53
108.246.55.35
Re: 300 Utility hydraulic questions in reply to Bill Lisbon, 11-10-2012 10:36:29
And the white is water in the hydraulic fluid.
  [Reply]  [No Email]
Janicholson
11-10-2012 10:51:12
96.24.99.126
The pilot valve or its screen (small) is at the limit of plugged up. I believe it is located in the first control valve attached to the reservoir. the leak is different, and is an Oring in the fitting. Jim
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
