Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 886 360cid inj.pump
pete 23
11-10-2012 09:46:45
Leaking around the head of pump usually requires the housing be replaced as they get a groove worn in them and then a new o-ring will not seal. You would need pump completely gone through.
To remove pump, remove the side cover, four screws, turn engine until mark comes around on gear, then turn a little more until timing mark lines on hub up with pointer which is under front pump cover. That will be about 18 degrees before tdc on front pulley.
