Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: M Hydraulics
IH fan
11-10-2012 07:49:18
Sparky2 said: (quoted from post at 09:33:25 11/10/12) Thanks, I appreciate your candid comments, I need
straight talk. Well, I can build a tank relatively
easy but I see the Surplus place in NE has them for
$100.00. I am not sure of the tank or PTO size I
need. I see they vary in GPM and I assume that means
the more GPM the faster the log split or whatever
will run. I am still thinking about a 3 pt hoe and
most of them come with a pump. I installed a Saginaw
3 pt on the M months ago. Appreciate the inputs,
helps a ton.
Remember when you are looking at pumps, they are rated at a particular RPM, so you need to take that into consideration. Most pumps are rated at 1800 or 2000 rpm so with an M running a slower speed and driving off the crankshaft, you won't have the rated flow. I have a 240U with a crank driven pump and I am a firm believer in live hydraulics. If you've used them on your 300, you will miss it if you don't go that direction.
Not sure you will need tospend $900 if you already have the mount for a crank driven pump. Northern Hydraulics has them for less unless you get really extravagent. You need one with a keyed shaft and not a spline so you can lock it up solid with the coupler.
This post was edited by IH fan at 07:50:05 11/10/12.
Sparky2
11-10-2012 09:26:50
 Re: M Hydraulics in reply to IH fan, 11-10-2012 07:49:18
Thanks, yes I like the live hydraulics on the 300. I called Northern Tool. They do not have a pump listing by application....i.e. 1951 Farmall M. They told me to call back with bolt pattern, GPM flow, open or closed and something else I cannot remember. Do you know how I can obtain this type info,,,,thanks again and standing by
Copyright © 1997-2015 Yesterday's Tractor Co.
