hydraulic pump id
Anonymous-0
Can anyone tell me what the difference is between a thompson or pesco pump on a super c? Are there any visible differences without tearing it all apart? I am looking to order all the orings, gaskets, wear items out of the ih catalog and it shows a different set of part numbers for each of them.
Find the numbers on the pump, you will probably have to remove it first. Those pumps are basically not repairable. About all you can get are gaskets and seals, there is no real kit. The orings/seals you mentioned can be bought about anywhere.
