Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Janicholson or anyone else, what to try next?
TractormanNC
11-06-2012 12:28:35
If your water pump looks like the one in the picture, you have found your problem. the water pump is NOT turning. Two of the 4 bolts in the front of the pulley need to be replaced by studs which go through the two vacant holes in the front cross piece (the driver). two springs go between the hex on the studs and the back side of the driver. The driver must be removed to put the springs on.
The Red
11-06-2012 12:32:00
 Re: Janicholson or anyone else, what to try next? in reply to TractormanNC, 11-06-2012 12:28:35
Totally agree. I just got back from the minibarn. I have an H pump assembly. Anthony all it is doing is turning the fan blade. You need those pins and springs so the blade can turn that front impellar on the pump shaft.
