Yesterday's Tractor Co. Fast, Friendly Parts Service
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 966 clutch PTO
[Return to Forum]
CRAIGREAVLEY
11-06-2012 09:56:21
198.102.252.12
How difficult is it to rebuild the PTO on a 966. Does it require special tools? Can the average shade tree mechanic figure it out. i know you have to drain all hy-tran out to do it??? What manual would be best for accurate instructions???
[Reply]   [No Email]
mkirsch
11-07-2012 06:05:06
64.80.110.75
 Re: 966 clutch PTO in reply to CRAIGREAVLEY, 11-06-2012 09:56:21
We literally used to pull the PTO units under the shade tree, because there was a very short, steep hill there. Back the tractor up on the hill so you didn't have to dump the hydraulic oil.
[Reply]  [No Email]
Owen Aaland
11-06-2012 22:08:17
216.47.35.118
 Re: 966 clutch PTO in reply to cjd12000, 11-06-2012 09:56:21
Takes about a half hour to do just the clutch pack. Run the front end down in the ditch. Pull the PTO. Four bolts and a snap ring and you can get the clutch plates out. Then a week later you can do it again because when the clutch failed it cooked the seal and caused the new clutch pack failed.
[Reply]  [No Email]
rktman
11-06-2012 14:46:24
75.121.71.51
 Re: 966 clutch PTO in reply to David G, 11-06-2012 09:56:21
Lol, I was close
[Reply]  [No Email]
The tractor vet
11-06-2012 14:42:16
75.24.0.62
It all depends on how deep ya want to go into it . IF you want to replace the clutch pack then the only thing ya need is the fitting to go into the test port and a good hyd . pressure gauge to check and reset if needed and a cherry picker to help ya remove and install . If you want to go deeper then ya need a spring compressor to compress the spring to get the clutch drum off to get back into the brakes and seals. , and you will need a piston ring compressor to compress the new teflon seals when you install them . a seal driver helps when installing the seals.
[Reply]  [No Email]
rktman
11-06-2012 14:38:09
75.121.71.51
Most will probably say to take it to a shop to have it done. It requires a special spring compressor tool and the pressure gauge to set it correctly.
T.V. will tell you how he could do with one hand behind his back and one eye plucked out in about 3 hours. You will probably want the original manual from Binder Books.
[Reply]  [No Email]
The tractor vet
11-06-2012 14:44:43
75.24.0.62
 Re: 966 clutch PTO in reply to rktman, 11-06-2012 14:38:09
No it takes about three and a half hours to go thru one . So you must just wish you had the stuff to do it with.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
