Woods Mower
i just took off my woods L59 belly mower for winter and i need some ideas on a rear swivel caster wheel just to push this puppy around its heavy well made.use a floor jack to remove.
1-caster wheel?
2-non swivel wheel since front swivel?
3-will be stored on flat level ground
4-in the picture with yellow outline is where i would like to put this.
4-thanks for any help
I would put a swivel wheel back there, makes turning corners easier. You will need to make the wide swivel caster shank long enough so that it can be adjusted for heighth. I used one from John Deere to retrofit mine.
Good luck ! Jim B. in Oregon
Just take a piece of angle iron weld 2 ears on the end so you can pin it to the existing bracket. Then put a handle on it so you can pull it or push it around. The handle wants to be straight up when parked this way when you pull it down some it will lift the front of the deck. This method would also keep it from rolling after let down. The amount of lift will be determined by the angles of the wheels and handle.
