bill engel
New User
I have a M farmall which I converted to 12 volt several years ago. It has the delco alternator, a 6 volt coil, and a ballast resistor..and has been working fine all along. Today, I started the tractor, warmed it up, and ran up the throttle til the ammeter went into charge mode. I turned on the headlights, just to see if they still worked. They did, but then i noticed the ammeter pegged all the way to the right, and the engine stopped running. I have no spark coming out of the coil. The headlights still work. I do have proper continuity throughout the circuit. The resistance across the ballast resistor is 0.00. According to the spec, it should be around 1.5 ohm. Did I perhaps fry the resistor, and or the coil? Thinking about bypassing the resistor, and installing a 12 v coil. Any advice, I would greatly appreciate.
