Yesterday's Tractor Co. Same-Day Parts Shipping Available
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: C-123 C motor rear main seal.
[Return to Forum]
Joshua Rod
11-05-2012 10:19:34
66.188.152.130
I've had a small oil leak under the tractor for
years. Last Feb. put new gaskets on the oil pump
assembly (since it was apart) and replaced the oil
pan gasket. Still leaks. Now I have to believe it
is the rear main seal. I have worked on many
engines over the years and never had any issues
with this type of repair. However, everything i
have done with seals like this were when the motor
was upside down on a stand. Can i do this with
the motor still in place or is it near impossible?
Is it hard to get the bearing and cap back in
place?
I know someone out there has tried this...
[Reply]   [No Email]
charlieu
11-05-2012 19:28:20
209.131.227.57
 Re: C-123 C motor rear main seal. in reply to Joshua Rod, 11-05-2012 10:19:34
Here is a picture of a splitting stand that I designed to split a Farmall A, B and C series tractor. The stand is shown on a BN. Once the flywheel is removed the seal retainer can be removed. Two pieces of felt are used to seal around the crankshaft. Make sure to check the holder for warping, they have the tendency to warp badly. My local machine shop is able to flaten them so they can be reused. Good luck.
[Reply]  [No Email]
pete 23
11-05-2012 18:27:58
74.32.238.2
Rear seal is in behind flywheel in a pot metal two piece retainer. Seal is two piece felt. Also, there is a pot metal plate under the retainer. Both warp out of shape seriously. You can service both with a split at clutch housing and pan removed.
[Reply]  [No Email]
pete 23
11-05-2012 18:27:58
74.32.238.2
[Reply]  [No Email]
Joshua Rod
11-05-2012 12:35:08
66.188.152.130
Thanks guys, I knew someone's been through this. Best to know this now before i get stuck and it requires a complete teardown. (I have a tendancy to bite off more than i can chew)
[Reply]  [No Email]
BARRY HOWARD
11-05-2012 12:13:29
12.45.50.5
I thought my seal was leaking, turned out my oil pan had a small hole near the bellhousing end. Check that 1st.
Barry
[Reply]  [No Email]
CharlieNJ
11-05-2012 12:01:14
76.117.68.151
Joshua, you need the flywheel off the crankshaft to service that rear main. So you do it on the engine stand or the bench.
Regards,
Charlie
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
