Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
My Budget Build Snow Blade
bob hawbecker
11-04-2012 14:18:58
i have a super A tractor
and wanted a snow blade for some time but they are hard to fine so we decided on a budget build.
this blade is from cub tractor 54A type.
most of this build was in the mount for the tractor all mounts needed 4" wider
this project was not to bad if you have the tools (welder and mill and metal saw)so here it is my budget build hope you enjoy.
Tom Fleming
11-05-2012 05:10:43
 Re: My Budget Build Snow Blade in reply to bob hawbecker, 11-04-2012 14:18:58
I plow snow all the time with my cub and the factory setup. Yes, you can bust the tool mount casting but only if you run it into something full speed and that "something" doesn't move.
These are NOT a D9. I have used mine for snow, and and push the dirt back into trenches when installing sewage or electric underground service. They are fantastic for that. Cub or A, a great little pushing machine.............when used as intended.
PretendFarmer
11-05-2012 04:37:11
 Re: My Budget Build Snow Blade in reply to CenTex Farmall, 11-04-2012 14:18:58
Only reason I mention having bars to the final drives is because I've heard of people busting the front end off on cubs if they didnt have those bars. I doubt it would happen but you never know. Would be a shame if it happened.
Tom Fleming
11-05-2012 01:52:10
Looks good. Beats a shovel and a sore back ANY day of the week! Seriously, nice neat and clean job on it. Previous comments are correct, but in a pinch, it WILL do the job.
sflem849
11-04-2012 19:20:02
Looks nice enough, but too narrow. I would guess the snow will roll around the back and you will be running it over. Can't angle the blade at all or you are packing snow. In the end you worked with what you had. Nice work.
GordoSD
11-04-2012 15:08:06
I made a leading edge blade scraper (squeege) from a 5/16 x 5inch wide strip of rubber from a conveyor belt material. It is reinforced with three different layers of nylon thread.
PretendFarmer
11-04-2012 14:54:44
 Re: My Budget Build Snow Blade in reply to John G. Hasler, 11-04-2012 14:18:58
A word to the wise, you may want to run some bars back to the final drives from your plow setup. Take note of mine.
tntleake
11-04-2012 14:26:43
Excellent, nice job
farmallday
11-04-2012 17:23:34
 Re: My Budget Build Snow Blade in reply to tntleake, 11-04-2012 14:26:43
love it good job!!
Copyright © 1997-2015 Yesterday's Tractor Co.
