| Farmall & IHC Tractors Discussion Forum |
Topic: farmall oiling
[Return to Forum]
| Author |
[Modern View]
| williamscarfan
11-04-2012 12:18:53
162.40.217.102
I have a 1958 FA, 240 with oiling problems, when it's cold the oil pressure is 45 lb after about 10 min. its down to 0. That's the easy part, the one I don't get is that the oil on the dip stick is just like the day it was put in and the oil at the drain plug is dirty and black like it should be. Why isn't the oil circulating, is there an oil pump or are there slingers ?? Thank's for the help in advance. Larry |
[Reply] [No Email] | |
| rhtx55
11-05-2012 17:17:16
68.185.207.25
Re: farmall oiling in reply to williamscarfan, 11-04-2012 12:18:53
| Double check to see that you have the correct oil filter first.
If not,
Sounds like the oil may be dropping below the oil pump pick up for some reason.
That or the by-pass releif valve spring is sprung, spring not stout enough to hold up when it gets warm.
Double check the oil level, I would simply change the oil & filter to be sure of the viscosity & amount first & go from there.
How long has it had this warm oil pressure symptom?
Has it gradually become worse, or was it sudden? |
| Owen Aaland
11-04-2012 21:19:01
216.47.35.85
| Any tractor with a C113, C123, C135, C146, or C153 is subject to having a warped oil pump cover since they all use pumps with aluminum covers. When the cover warps the shim gaskets blow out ans you lose oil pressure. |
| williamscarfan
11-05-2012 08:07:37
162.40.217.102
Re: farmall oiling in reply to Owen Aaland, 11-04-2012 21:19:01
| If I need a new oil pump any good place to get one? |
| CNKS
11-05-2012 08:38:34
216.144.104.128
Re: farmall oiling in reply to williamscarfan, 11-05-2012 08:07:37
| CaseIH still has the lower plate that warps. Many have been successful just sanding the old one flat. |
| stumper
11-04-2012 16:06:27
24.247.104.181
| everyones sugestions are good,but also check the oil relief valve I think it is on the oil pump. Good luck, stumper |
| Janicholson
11-04-2012 15:54:08
96.24.99.126
| Make sure the oil pump cover is flat. <001 to .0005 end clearance. Jim |
| The tractor vet
11-04-2012 12:51:53
75.24.0.62
| Like others have said drop the pan and see . BUT if it drops off that bad that fast then ya may have a big problem with main bearings rod bearings and cam bearings .And also the oil pump. |
| The Red
11-04-2012 12:40:20
69.246.205.0
| If I had that problem on one of my Hs or Ms, I would be dropping the oil pan. Clean it out and clean the inlet screen on the oil pump. Sounds like sludge in the bottom of the oil pan. |
| old
11-04-2012 12:23:05
209.86.226.32
| Yes they have oil pumps and a lot depends on the type of oil you have and all that as for the PSI. If your running a 10W30 oil try a 30W oil since the muti weight oil like 10W30 is 10W oil with additives that make it act like a 30W when warm |
| williamscarfan
11-04-2012 15:21:19
162.40.217.102
Re: farmall oiling in reply to old, 11-04-2012 12:23:05
| thanks for all the good ideas. I"ll drop the pan in the next few days and see what"s there. The bearing are my thought on losing psi. but I would think with any psi at all I would be getting some movement of oil in the oil pan? |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
