antifreeze or water
Anonymous-0
well guys can you tell me how mutch power you gain in horsepower by runing water insted of antifreeze i know it makes a diffrence is it that water is thiner ?
I don't know if there is any difference in power output, but I wouldn't take the risk of straight water. Too much is at stake .
I wonder where you ever got that idea.
I've never heard that before, and I can't imagine what difference it could possibly make.
You will not gain horsepower from changing coolant to water. You will inherit problems with straight water. Rust, boil over, freezing, are just a few that come to mind.
WELL TO ANSWER YOUR QUESTION IN PULLING TRACTORS OR TRUCKS OR WHATEVER THERE IS LESS DRAG ON THE MOTOR THROUGH THE WATER PUMP GENERATED FLOW WITH WATER IT AA THINER VESCOSITY THAN SURUP
Most race car and pulling events use water only due to ground contamination issues. I have run water wetter in the cooling system and it will make it run about 10 degrees cooler. Speedway motors in NE sells it.
how do you know it makes a difference? the only h.p. you would gain is if you replaced the fan with an electric one. just my own thought would be that antifreeze would have less friction going around corners than water. also antifreeze will find seep spots before water.i am talking a 50/50 mixture not pure antifreeze.
In that case you should run straight methanol. Or better yet, anhydrous ammonia. You may want to redesign your cooling system for the latter, though.
HP change is negligable between glycol/water. The racers use water because they dump out the hot water between races and do not encounter freezing conditions.
A 50/50 mix is the best compromise between cooling, corrosion prevention and freezing prevention. The pressure cap does more for boiling prevention then the glycol.
Sorry but that is just a silly wives tail. Sort of like the one that says you gain a lot of extra HP by running with out a muffler. Ya the muffler thing does in fact boost HP a bit but so little you can not see the difference
I've been running antifreeze mixed 50-50 with water for 40+ years and it has never been the viscosity of syrup.
Those guys must have been using something different than what is sold around here.
i never heard of a power increase with just water but i know from experience that straight water will give you around 20% more cooling capacity than an antifreeze mix will. the surface tension of water is less than the mix.
I did check the viscosity numbers, 50/50 mix has a viscosity of around 20 at freezing, and goes down to 2 at 200 degrees. Water has viscosity of about 1 within those ranges.
A thicker liquid will take more HP, but the differences in viscosity is negligible at operating temperatures.
Good theory, but you got it hind end around bassackwards.
Back in 50s, early 60s people in warm climates such as so Tx, Fl, Az, Ca ran just a quart of antifreeze to lube water pump & in case they got a little frost.
Then with A/C becoming a popular option, they had overheating problem due to the increased cooling load. Remedy was to run 50/50 mix in everything year around.
Willie
No one has mentioned that antifreeze raises the boiling point, thus less or nothing comes out the overflow. In S Texas I don't think we ever used antifreeze in the 50's. If the occasional freezing temps were forecast we drained the radiators in both tractors and cars. We ran our H fully loaded a lot of the time and loss of coolant was not unusual. Antifreeze would have stopped that.
