| Farmall & IHC Tractors Discussion Forum |
Topic: Steering wheel
[Return to Forum]
| Author |
[Modern View]
| j strickland
11-03-2012 18:41:51
71.82.36.253
I am winding down for the start of winter, just a few small items to tie down. One of them is the Steering wheel, how do I keep from getting black hands when I use the steering wheel? Also I need to tighten up the slop in the steering if possible. It is on a 1941 Farmall A. The steering wheel black is all there it just leaves a black stain on your hands. The slop is about a third of a turn. Is there a adjustment somewhere to tighten it up?Thanks, James |
[Reply] [No Email] | |
| Dave Sherburne NY
11-04-2012 10:35:16
74.32.166.203
Re: Steering wheel in reply to j strickland, 11-03-2012 18:41:51
| This was just discussed 2 weeks ago. Since you have a 1941. It probably has the old style steering arm and shaft where the steering arm clamps to the shaft. Do like Gene said and when you get to the steering arm you'll probably find it real loose on the vertical shaft. It can be shimmed with a piece of soup can for a temporary fix. When you get the time and money replace bearings, shims and key. IH used to have a kit to change the old style straight vertical shaft to the newer one that is tapered on the bottom NLA but all the parts are still available to make the change over. When I did mine it was about $150 for steering arm and the vertical shaft but when I finished it was tight and still is. |
| jbp
11-04-2012 08:39:07
64.57.160.3
| As for keeping the black off your hands, spray truck bed liner works very well. It gives a slightly rough texture to the surface but not enough to be hard on the hands. Its also tough as nails and will last nearly forever. Its also cheap and easy to apply. Joe |
| gene bender
11-04-2012 04:17:57
207.177.56.85
| Just get a spray bomb of gloss black paint and give it a couple of coats. Sart at the tie rods and work backwards to the drag link if theres end play in the steering sgaft remove the big nut abd replace the bearing. Then if ther is still lots of play you need to remove the whole assy and go thru that there are bushings some seals and a bearing also there is a key in the geag when you are done it will be like new again ive done several. |
| BOB HAWBECKER
11-03-2012 20:20:53
71.173.208.237
|  i use this one i think its off a 100 or 140 much nicer wheel and a little larger than the stock metal spoke wheel. also no dirty hands |
| steve706
11-03-2012 19:57:54
216.208.94.103
| The best thing I have found for old steering wheels and rubber is De-ice boot cleaner and sealant by BF Goodrich. The stuff is used to clean up wing de-ice boots on the leading edge of aircraft wings and works better than anything I have ever tried. It get's into the structure of the steering wheel and seals it up and does not leave a slippery finish. The stuff is great and works on any rubber you have on your tractor. A pint bottle has lasted me more than 5 years and it's not even half empty. |
| Janicholson
11-03-2012 19:36:41
96.24.99.126
| Clean it with a lacquer Thinner rag (Damp, not soaked)sand it with 150 grit paper to give it tooth. Paint it with black automotive touchup paint. The black is the original compounds rubbing off from oxidation. The slop is in one of the following: Bearing at the end of the worm (in and out Play) Bushings on sector shaft (up and down play) Bushings on Sector shaft (sideways) Key on sector shaft loose in sector Fit of steering arm on sector shaft (could be tapered square, or tapered woodruff key style Loose tie rod ends (might be adjustable) Loose spindle bearings Jim |
| uncle henry
11-03-2012 19:18:00
67.223.201.52
| i wear gloves got a new steering wheel on one still have the same thing |
| gene bender
11-04-2012 04:19:04
207.177.56.85
Re: Steering wheel in reply to uncle henry, 11-03-2012 19:18:00
| give it a coat of paint |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
