| Farmall & IHC Tractors Discussion Forum |
Topic: Re: Farmall H hydraulics
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| longgun708
11-03-2012 10:39:47
67.190.16.200
I finally found an ID number on them. It says on the under side of the arm an IHC logo stamped in the arm with the numbers 450 657 R2 I googled this number 7 ways from Sunday with IHC int etc with no hits that meant anything so I can't positively ID it. |
[Reply] [No Email] | |
| Janicholson
11-03-2012 10:54:36
96.24.99.126
Re: Farmall H hydraulics in reply to longgun708, 11-03-2012 10:39:47
| I believe Rusty is correct in that the upper cylinder volume will supply extra fluid to assure full travel. I believe he is incorrect in indicating that the cylinders are working as designed. They are leaking, or oil would not get to the top of the cylinder as you describe. I also believe the best place to route the hoses back to the reservoir is in the drain plug at the bottom of the reservoir. A short pipe nipple, and a cross fitting at that spot will allow draining the system, as well as attaching two hoses for the return. As I noted, the problem for using the loader would be made to go away, but the piston seals in the cylinder are still leaking. Jim |
| rustyfarmall
11-04-2012 11:41:40
216.248.71.226
Re: Farmall H hydraulics in reply to Janicholson, 11-03-2012 10:54:36
| Quoting Removed, click Modern View to see
The method I described for routing the hoses back to the reservoir was taken directly from the McCormick #31 owners manual. However, the part number given by the original poster is too new for a #31 loader, so it might just be that the loader he has is actually set-up for 2-way hydraulics, which his H does not have, and then installing those vent plugs in place of hoses IS correct, and yes, the cylinders need to be rebuilt. |
| longgun708
11-04-2012 19:30:16
67.190.16.200
Re: Farmall H hydraulics in reply to rustyfarmall, 11-04-2012 11:41:40
| | Thanks, I'm looking into it tomorrow. Raymond |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
