Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: 263 CC gas carb
pete 23
11-02-2012 20:12:14
Carburetor kits should be named fits. Usually they give you a bunch of junk you don't need and the parts you want are not in there anyway. When I order parts I order individual parts. You never get the throttle shaft bushings in a kit and they are often needed. If you get a new nozzle, nine chances out of ten it will not be the correct on and carb will never work properly again. Air bleeds are not included and don't wear out anyway. Main jets are impossible to find, won't come in any kit and you only need them if someone has drilled out the old ones. In other words, like Tractor Vet said, get the parts you need. Forget the kits.
jerry Gilliam
11-03-2012 06:26:43
 Re: 263 CC gas carb in reply to pete 23, 11-02-2012 20:12:14
good post, and about what I have found in the past.
11-03-2012 08:43:12
 Re: 263 CC gas carb in reply to jerry Gilliam, 11-03-2012 06:26:43
The same basic gasket kit with needle valve and seat that fits a Farmall M carburetor will work just fine. About $10.
Jerry Gilliam
11-04-2012 06:08:16
 Re: 263 CC gas carb in reply to rustyfarmall, 11-03-2012 08:43:12
