Yesterday's Tractor Co. Trusted Parts Supplier since 1995
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Farmall H hydraulics
[Return to Forum]
longgun708
11-02-2012 18:07:07
67.190.16.200
Hi, I have a 47 farmall H with a loader and the loader squirts hydraulic fluid out of what appear to be a square headed fitting with a hole drilled it in. The fitting is right where the stainless steel arm goes into the cylinder. It does it on both of the arms when I raise the bucket. Especially at the upper range.It does it every time until it seems to run out of fluid, the it really seems to labor lifting the bucket that high. There is no name on the loader. Can anyone tell me what is wrong and how to fix it?
Thanks
[Reply]   [No Email]
mkirsch
11-05-2012 08:08:24
64.80.110.74
Re: Farmall H hydraulics in reply to longgun708, 11-02-2012 18:07:07
It may be normal for the cylinders to squirt some oil out the first few times IFFF they had just been re-plumbed.
After a few cycles, all the old "reservoir" oil should be pushed out. If the cylinders keep pushing oil, they are leaking around the pistons.
Be aware that some cylinders cannot be rebuilt.
  [Reply]  [No Email]
rustyfarmall
11-03-2012 07:45:31
216.248.71.226
If the loader is a McCormick #30 or #31, the cylinders are designed so as to have a reservoir at the front end of the cylinders. The reservoirs are there to supply needed hydraulic oil to the belly pump, because the belly pump does NOT have the capacity needed to supply ENOUGH fluid to fully raise the loader.
As the loader is raised, the fluid in the cylinder reservoir is pushed back into the belly pump reservoir, thus providing sufficient fluid to fully extend the cylinders.
Remove those air vent plugs and replace them with hydraulic hoses.
The other end of those hoses, both of them, then need to be connected with a TEE pipe fitting, and that TEE fitting can then be fitted to the belly pump fill pipe, using a pipe union fitting. The union fitting is needed to provide a way to fill the belly pump when necessary.
There is NOTHING wrong with your cylinders. They are doing EXACTLY what they were designed to do.
  [Reply]  [No Email]
longgun708
11-03-2012 10:39:47
67.190.16.200
Re: Farmall H hydraulics in reply to rustyfarmall, 11-03-2012 07:45:31
I finally found an ID number on them. It says on the under side of the arm an IHC logo stamped in the arm with the numbers 450 657 R2 I googled this number 7 ways from Sunday with IHC int etc with no hits that meant anything so I can't positively ID it.
  [Reply]  [No Email]
Janicholson
11-03-2012 10:54:36
96.24.99.126
Re: Farmall H hydraulics in reply to longgun708, 11-03-2012 10:39:47
I believe Rusty is correct in that the upper cylinder volume will supply extra fluid to assure full travel. I believe he is incorrect in indicating that the cylinders are working as designed. They are leaking, or oil would not get to the top of the cylinder as you describe.
I also believe the best place to route the hoses back to the reservoir is in the drain plug at the bottom of the reservoir. A short pipe nipple, and a cross fitting at that spot will allow draining the system, as well as attaching two hoses for the return.
As I noted, the problem for using the loader would be made to go away, but the piston seals in the cylinder are still leaking. Jim
  [Reply]  [No Email]
rustyfarmall
11-04-2012 11:41:40
216.248.71.226
Re: Farmall H hydraulics in reply to Janicholson, 11-03-2012 10:54:36
The method I described for routing the hoses back to the reservoir was taken directly from the McCormick #31 owners manual. However, the part number given by the original poster is too new for a #31 loader, so it might just be that the loader he has is actually set-up for 2-way hydraulics, which his H does not have, and then installing those vent plugs in place of hoses IS correct, and yes, the cylinders need to be rebuilt.
  [Reply]  [No Email]
longgun708
11-04-2012 19:30:16
67.190.16.200
Re: Farmall H hydraulics in reply to rustyfarmall, 11-04-2012 11:41:40
Thanks, I'm looking into it tomorrow.
Raymond
  [Reply]  [No Email]
Janicholson
11-02-2012 18:28:41
96.24.99.126
Dave has it correctly identified. Rebuild the lift cylinders, or it will continue to do it. OOORRR, you could plumb hoses into those ports, and have the leakage return to the reservoir. This will not fix it, but it will keep it from binding at the top of the travel, and allow continued use as is. Do not trust it for life risking action (like getting under the bucket, or standing in it to put up lights!!) The rebuilding will cost less than the hoses and fittings. Make sure the plugs with holes are pointed downward when reinstalling them so water does not have a chance to enter. also do not let the tractor sit with the loader up, it just leaks down past the piston packing/seals and makes it worse. Jim
  [Reply]  [No Email]
longgun708
11-02-2012 18:45:17
67.190.16.200
Re: Farmall H hydraulics in reply to Janicholson, 11-02-2012 18:28:41
Thank you so much, I'll get to work on replacing or repairing. Good tips it would have taken ke the hard way to figure out.
Thanks
  [Reply]  [No Email]
David G
11-02-2012 18:14:25
205.215.206.18
I would assume those are vent plugs for the upper end of the cylinder and the seals are leaking in the cylinders.
  [Reply]  [No Email]
longgun708
11-02-2012 18:24:46
67.190.16.200
Re: Farmall H hydraulics in reply to David G, 11-02-2012 18:14:25
That may be. I would call them vent plugs. So I guess I need to have the cylinders rebuilt? Is it expensive? Can I do it myself?
  [Reply]  [No Email]
Ed Hotaling
11-02-2012 18:57:48
67.240.55.230
Re: Farmall H hydraulics in reply to longgun708, 11-02-2012 18:24:46
I had the same problem with mine a few years ago. My CIH dealer ordered the parts for me and it took maybe an hour each to disassemble the cylinders, clean them out and reassemble them with new parts. It made the loader work like new.
  [Reply]  [No Email]
longgun708
11-03-2012 06:47:02
67.190.16.200
Re: Farmall H hydraulics in reply to Ed Hotaling, 11-02-2012 18:57:48
Thanks, I'll find one here and give them a call.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
