| Farmall & IHC Tractors Discussion Forum |
Topic: Valve lube on old McC-D tractors
[Return to Forum]
| Author |
[Modern View]
| LenNH
11-02-2012 14:59:57
75.69.100.76
It seems like it would not be too hard to rig up continuous lubrication of the valve train--on 10-20, F-20 and others with that type engine--by hooking into the supply line to the filter. Anybody ever seen such a thing? I have always been suprirsed that IHC could go until 1939 with an oiling system up on top that was about as primitive as you could get. |
[Reply] [No Email] | |
| willie in mn
11-02-2012 17:59:20
67.142.168.27
Re: Valve lube on old McC-D tractors in reply to LenNH, 11-02-2012 14:59:57
| Some where around 52 or 53 Dad had the dealer put a valve oiler kit on the Regular. All I remember is the copper tube running up rear of block to rocker cover. Took care of itself. Until then had to pour some oil in the cups on top every day. Willie |
| 36F30
11-02-2012 17:29:07
67.3.82.81
LenNH said: (quoted from post at 14:59:57 11/02/12) It seems like it would not be too hard to rig up continuous lubrication of the valve train--on 10-20, F-20 and others with that type engine--by hooking into the supply line to the filter. Anybody ever seen such a thing?
You would have to make internal modifications to the block. The way the engines are built all of the oil and condensation from the head runs into the cavity in the side of the block where the push rod tubes are located. There is a tin deflector that covers a tube coming up from the lower end of the block. The stuff that accumulates in this cavity is then supposedly vaporized and vented out the pipe at the right rear of the block.
There were valve oiling systems made with a valve in them, copper lines running up to the valve cover to where the oilers were. After starting the engine you could open the valve for a short time and oil the top end but if you didn't shut it off you would eventually run all your oil out on the ground.
This post was edited by 36F30 at 17:31:02 11/02/12. |
| Old-F20
11-02-2012 19:49:27
71.7.101.5
Re: Valve lube on old McC-D tractors in reply to 36F30, 11-02-2012 17:29:07
| Quoting Removed, click Modern View to see
pretty much sums it up. if you constanly lube the valvetrain with oil from the crankcase your gonna run out and you can guess what will happen.
i plow alot with one of my W-30's and i dont find it difficult to manually oil the vavle tray once a day with a squirt can :wink: |
| rustred
11-02-2012 15:44:00
72.172.100.113
| the 15-30's did not even have an oil filter.filters came out on 22-36 and the later 1020's. but ya lot of these old tractors have the valve guides worn right out due to lack of oil. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
