Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Adding 2 way hydraulics to super M
D Slater
11-02-2012 06:30:04
Thinking maybe you want to get pressure from one of the pressure ports and then mount a control valve for double acting cylinders where handy. Run hose from pressure port to valve inlet. Return line from valve to drain plug on the transmission driven liftall. Put a tee in so it can still be drained. If its live hydraulic with the unit under the tank its the same hookup but the return line goes to the fill opening but that leads to trouble sometimes. A tee installed in the pump suction line works with the return hose going in the tee. Other openings on the valve are plumbed to the cylinders. Needs to be a open center valve. Also the liftall unit rod need to be locked in the pump position when using the add on valve. Relief valve in the liftall unit will still work to control the pressure. If thats not the way you were meaning let me know.
