TractorLinks.com
Show Parts for Model:
6 volt coil
dougct
11-02-2012 05:41:24
I had my generator re-wrapped to make it 12volt.I have a distributor,do i need to change my 6 volt coil to a 12 volt,also do i need to run a regulator or a cutout?Thank"s
old
11-02-2012 08:56:50
 Re: 6 volt coil in reply to dougct, 11-02-2012 05:41:24
You can replace your coil and get one that say no external resister needed or keep the coil you have an add a ballast resister like the O'Reilly's part # VR-1 which is small and easy to hide and the way it mounts you have a good heat sink so it lasts longer then most
TractormanNC
11-02-2012 08:43:07
Use a regulator instead of the cutout. Your battery will live much longer.
rustyfarmall
11-02-2012 07:13:55
You need to add an external resistor (cheapest way) or buy an internally resisted universal coil.
A coil that is labled for use on a 12 volt system STILL requires an external resistor.
DeltaRed
11-02-2012 06:46:09
As Cowman says,you will need to add a resistor.If you don't do this,you will need to buy a new coil in about 3 hrs.Don't ask how I know this......"smokin"!
Nebraska Cowman
11-02-2012 06:00:25
You need to add an external resistor ahead of your coil.
