TractorLinks.com
Show Parts for Model:
Early Farmall 706 Diesel (D-282 Engine) Tachometer Drive.
Crgmor
11-02-2012 05:14:09
Anyone have experience with removing the tachometer drive from the block of a early 706 diesel? Is it pressed into the block or screwed in? There are not visible clamps that hold it down like a normal distributor. I have stripped gears and need to look at the lower gear.
pete 23
11-02-2012 11:06:29
 Re: Early Farmall 706 Diesel (D-282 Engine) Tachometer Drive. in reply to Crgmor, 11-02-2012 05:14:09
If you have no luck getting gear out with plug removed, the adaptor is just a light drive fit into block and a brass drift and hammer will punch it out. Or, could hook a slide hammer onto it.
Crgmor
11-03-2012 15:06:09
 Re: Early Farmall 706 Diesel (D-282 Engine) Tachometer Drive. in reply to pete 23, 11-02-2012 11:06:29
Thanks. I will try to drive it up and out tomorrow if I can find a long enough drift. Do you know enough to tell if the oil pump drive can fall out like some automotive engines do or is it captive?
Thanks
Craig
ejr-Ia.
11-02-2012 08:16:17
Take the top plug out the gears should come out the top they are turned by the oil pump shaft.
