Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: 350 throttle problem
11-01-2012 15:00:55
I've been into a few where those holes were severely worn, to the point the spring was almost ready to break through. I welded the hole shut and then drilled a new hole, which fixed the problem, but I like the idea of the hardened bushings even better.
The tractor vet
11-01-2012 16:52:33
 Re: 350 throttle problem in reply to rustyfarmall, 11-01-2012 15:00:55
You can use bearing bronze or a harder steel and PRESS them in with .0015-0025 interference fit , Drill the hole a little bigger then the dia. of the spring wire then champer both side so that the spring is riding on about half the total thickness of the bushing and also allows for ease of getting the spring in the holes . Doing this cures idling down problems and also make the gov. work like it should .
