Plowing with an F-20
Mark Poss
I am looking to pull a #8 2 bottom plow with an F-20. I will put the draw bar into the slots to get it as low as it will go but it still will be a lot higher than the farmall H that i usually pull it with. Will this be okay or should I try to add something to lower it? Thanks, Mark.
all my 20's and 30's have the drawbar support in the round solid mount hole on the top. i never put them in the long oval holes. i plow with a #8 just fine like this.
keep in mind you will have to completely adjust your plow to pull behind an F-20 to make it work correctly if you've been using it behind an H so your draft is correct
So the height of the draw bar doesnt matter? I knew I would have to hook toward the right to ride in the furrow properly. thanks for the input, Mark.
Read Page 15 & 18 of the tractor plowing manual
http://ia700409.us.archive.org/13/items/cu31924003310962/cu31924003310962.pdf
Wow.... thank you very much for posting this manual...I wish I would have had this weeks ago when I tried to plow with an F-20 for the first time.
