Cub rear rims
Can someone tell me if a Cub rear rim will fit a Massey Harris Pony. The width is 7 in. on Cub and 8 in. on Pony but not sure the 4 loops are the same. Both carry a 5/8 bolt. Thanks for your help. Larry
My guess is it will not fit. The wheel disk looks more like an A than a Cub. Cub and A rims do not mix.
Measure the bolt circles.
Probably not as Jim says the measurements are off just enough they wont interchamge with the A and B. You could try or we will never know.
I found out that the A, super A, b , 100, 130, are the same as the Pony but not the Cub. Just my luck, I found a nice set of tires and rims from a Cub near by. Thanks for the reply.
