Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: six volt starter
charlie M
10-31-2012 17:18:37
Could be locked up against the fly wheel. If you try to turn the engine by hand and it won't move thats the problem. You'll have to remove the starter bolts and pull the start out, then reinstall.It happens on the old tractors when the ring gear gets damaged from use.
linemechanic1
11-03-2012 21:14:34
 Re: six volt starter in reply to charlie M, 10-31-2012 17:18:37
My 350U has been converted to 12Volt and, once it starts spinning, it starts pretty good. However you described the problem I've had for a while now...having to pull the starter, allow the spur gear to retract, then reinstall and hope for the best. A real pain. Would chamferring the spur gear teeth a little more help guide them into the flywheel more reliably?
red theo
10-31-2012 17:28:01
Thanks charlie I will give it a try.
red theo
10-31-2012 17:28:01
Copyright © 1997-2015 Yesterday's Tractor Co.
