Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
10-31-2012 16:57:35
I have a 706 with a 301 diesel and the motor is bad. Will the motor plate on the tractor bolt up to a 806 motor and if not what motor will with out getting a new one made.
1030 TOM
11-03-2012 19:27:47
 Re: 706 in reply to BriBri, 10-31-2012 16:57:35
we left the turbo on fit nuder the hood nicely the adapter plate came out of penn.
11-02-2012 17:44:56
Thanks for all the info guys, a little food for thought lol
1030 TOM
11-01-2012 18:35:59
my son put a 5.9 cummins in a 656 that had a263 gas, the hood fit used the factory radiator and fan shroud , really nice conversion ,it will go in a 706 easy just a thought tom
11-03-2012 05:29:30
 Re: 706 in reply to 1030 TOM, 11-01-2012 18:35:59
Did u happen to leave the turbo on the cummins or take it off
The tractor vet
11-01-2012 17:01:43
The D301 is a combine engine made with out sleeves but basicly the same block as a D282 . Now as to if it will fit a D361 Nope not in your wildest dreams. So it comes down to either finding a D301 and going back to that of finding a D 282 . Or you can go gas .
11-01-2012 09:13:06
I didn't know there was a 301 diesel. Thought the early 706's had the 282 w/ glow plugs and the later ones had the 310 german. Even then there's a difference in frame lengths between those two engines, the 310 being longer. Either way a 361 from an 806 will be a tough fit like the other post said.
Casey in SD
11-01-2012 08:32:15
Parts book shows they are different.706 use 367224R2 plate and the 806 is 332446R21.You can put a 361 in the 706 but you will need allot of parts off a 806,frame rails,longer power steering lines ,grill,radiator,hood,air cleaner,lines,taller steering support,longer shifting shafts,throttle linkage,thats the big items.
