Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Plowing with an F-20
Mark Poss
10-31-2012 16:49:41
I am looking to pull a #8 2 bottom plow with an F-20. I will put the draw bar into the slots to get it as low as it will go but it still will be a lot higher than the farmall H that i usually pull it with. Will this be okay or should I try to add something to lower it? Thanks, Mark.
Earl-IL
11-01-2012 11:56:39
 Re: Plowing with an F-20 in reply to Mark Poss, 10-31-2012 16:49:41
Height should be 17-19 inches for proper line of draft.
Ron W
10-31-2012 20:53:15
Read Page 15 & 18 of the tractor plowing manual
http://ia700409.us.archive.org/13/items/cu31924003310962/cu31924003310962.pdf
rljgoss
11-01-2012 11:22:42
 Re: Plowing with an F-20 in reply to Ron W, 10-31-2012 20:53:15
Wow.... thank you very much for posting this manual...I wish I would have had this weeks ago when I tried to plow with an F-20 for the first time.
Mark Poss
10-31-2012 18:20:44
So the height of the draw bar doesnt matter? I knew I would have to hook toward the right to ride in the furrow properly. thanks for the input, Mark.
Old-F20
10-31-2012 18:11:00
all my 20's and 30's have the drawbar support in the round solid mount hole on the top. i never put them in the long oval holes. i plow with a #8 just fine like this.
keep in mind you will have to completely adjust your plow to pull behind an F-20 to make it work correctly if you've been using it behind an H so your draft is correct
