Yesterday's Tractor Co. Tractor Parts for All Brands
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: The old A has it in for me
[Show Entire Topic]  [Return to Forum]
kopeck
10-31-2012 12:03:53
169.244.197.208
I just replaced the strainer/bowl unit and that didn't help. I blew the line out last time I had it off (when I replaced the fuel strainer). It seems like a good flow.
It doesn't smoke and it doesn't seem to fouling any plugs BUT I don't run it all that long so I'm not so sure if that means a ton. I did try to run it with partial choke and couldn't find any place that really helped. That being said if I had to guess I would say it's running more lean then rich, it hasn't back fired or anything but it's not smokey that I can see.
K
[Reply]   [No Email]
Hendrik
10-31-2012 13:53:55
194.53.253.51
You said: "It seems like a good flow.".
How did you observe that? I'd remove the drain plug from the carb bowl and collect the gas in a container. Measure the amount after letting the gas flow for 15 minutes; should be at least a gallon. That amount may be regarded as "being available" to the jets. So, if the flow from the drain plug from the carb bowl is sufficient, the problem of lean running could be in the jets.
Other thoughts:
1) Is the venturi mounted properly?
2) Is there sufficient vacuum? Remove the pipe plug from the manifold (just above the flange to which the carb mounts) and screw a barb fitting in. Attach a transparent U-tube and fill with water. I must confess that I do not know how much vacuum it should register, but you could take this measurement form your B (or others may chime in...).
HTH, Hendrik
  [Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
