Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Farmall M 3 Point Backhoe
10-30-2012 19:03:49
i would guess the m could carry the hoe. they can handle a mounted corn picker or cotton picker conversion, prolly pretty close weight wise. for hydraulics to run the hoe, you want a pto driven pump. the belly pump is just too slow. you will need some weight in the front of the tractor too, as it will be way light going down the road, and make for some real pucker factor wheelies. maybe add a loader to the front of the m for some extra weight and a little more usefulness. you will need a pretty good size hydraulic oil resevoir too, so you dont dont over heat it.
10-30-2012 20:28:42
 Re: Farmall M 3 Point Backhoe in reply to glennster, 10-30-2012 19:03:49
Would a pair of IH front weights do the trick? Or not enough weight?
10-31-2012 03:04:30
 Re: Farmall M 3 Point Backhoe in reply to Sparky2, 10-30-2012 20:28:42
If you made a bracket to get the weight out front it may be enough. Also, you could mount a thirty or 55 gallon plastic drum on the front and then just add water for ballast as needed.
10-31-2012 05:13:22
 Re: Farmall M 3 Point Backhoe in reply to Glennster, 10-31-2012 03:04:30
So front wheel weights may not be enough. I could make a bracket for the front and add some weights of some kind, I guess a loader is really the answer, but good ones hard to find. Thanks
