Anonymous-0
Hello, I have a farmall 400 I just put together. I am missing a few parts including the air cleaner pipe from the carb to the air cleaner and the TA lever. Will a air cleaner pipe from a m fit, and what other tractor models are the same. I found a TA lever from a 350 but was wondering if it was to short to fully enguage it. What model tractors used the same TA lever? Finally, the narrow front end shakes like crazy when you get up to speed, is that something adjustable or once its worn there is no fix? Any info is appreciated, the little I have run it I really like the tractor!
