Yesterday's Tractor Co. Fast, Friendly Parts Service
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: tractor keeps running after its shut off
[Show Entire Topic]  [Return to Forum]
teddy52food
10-30-2012 06:23:42
184.94.175.179
Not out of time. When you turn it off the spark is gone. Idel it down for a while to cool off then ride the clutch in high gear as you turn it off.
[Reply]   [No Email]
Jon Hagen
10-30-2012 19:42:23
69.26.17.61
 Re: tractor keeps running after its shut off in reply to teddy52food, 10-30-2012 06:23:42
Teddy, up untill a couple of years ago, I would have agreed with you totally, ignition timing can not cause dieseling because the spark is shut off.
I proved myself wrong when working on an old V6- 478 GMC truck. This old critter always had a terrible dieseling problem when shut down warm.
It had an Allison automatic transmission, so I could not put it in gear and kill it with the clutch like you do with a manual transmission.
I had to idle the engine as slow as possible and shut it off with the automatic in gear, after a few minutes idle, but still it liked to crack and pop along,dieseling with the ignition off.
The truck always ran a little warm and had the dieseling problem, but I just wrote it off as the nature of the beast.
I noticed the old truck seemed to run the exhaust system very hot, as wiring and hoses near the exhaust manifolds tended to suffer from excess heat. I got to thinking, late ignition timing is usually the cause of high exhaust temp, might the timing marks be off on this engine ??
I checked and yep, the vibration damper outer ring had slipped and the timing marks were more than 10 degrees later than the marks indicated.
I repaired the timing marks, correctly timed the engine and noticed it ran cooler, had more power and the exhaust ran much cooler. Another amazing thing happened after fixing the timing problem, the old GMC no longer dieseled when shut down warm ??
I knew the ignition timing was shut off, so it could not be igniting the fuel, but it finally sunk in that the late timing had been causing the exhaust valves along with the exhaust manifolds to run very hot, this providing the "hot spot" to ignite the fuel and cause dieseling. Correct ignition timing allowed the exhaust valves to run cooler, so no more dieseling.
I guess what I learned from that is to never say never, as LATE ignition timing on this engine did indeed cause dieseling. :)
Cant hurt to recheck timing on the old farmall, it might be part of the problem, along with too fast an idle.
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
