Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: tractor keeps running after its shut off
old
10-29-2012 21:35:40
Running as in what is called dieseling or running as in true engine running?? If dieseling that is caused by hot spots in the engine which in turn is burning the fuel that is still being sucked into the engine from the carb. It is caused by carbon build up in the cylinder on the valves and the top of the pistons. On some it helps to pour a qt if ATF into 3-5 gal of gas and run it that way to clean out the carbon
DeltaRed
10-29-2012 21:56:49
 Re: tractor keeps running after its shut off in reply to old, 10-29-2012 21:35:40
My SM hasa done that for years,even right after it was o'hauled'.Timeing has been checked...Is this because it has too much cumpression?The head was 'planed',and it has hi-altitude stephead pistons.It's always been worked hard,so its never had a chance to get carboned up.Are there other things that could cause that?
old
10-29-2012 22:20:54
 Re: tractor keeps running after its shut off in reply to DeltaRed, 10-29-2012 21:56:49
Again can be caused by hot spots as in shut down with out letting it idle for a bit to cool down some. Of course if you turn off the gas then let it die that way then turn off the switch that will stop it or should
Kurt LaGrander
10-29-2012 22:13:24
Yes my 450 was just overhauled too. Not sure why it would be carboned up?
old
10-29-2012 22:22:48
 Re: tractor keeps running after its shut off in reply to Kurt LaGrander, 10-29-2012 22:13:24
No would not be from carbon but form hot spots caused by not letting it idle some to cool before shutting it off. Of course on way to stop the problem is shut off the gas let it die then turn off the ignition
scotc
10-30-2012 19:03:59
 Re: tractor keeps running after its shut off in reply to old, 10-29-2012 22:22:48
You could try a higher octane gas. The lower octane gas is detonating with good compression in the hot motor.
