| Farmall & IHC Tractors Discussion Forum |
Topic: Farmall H engine surges
[Return to Forum]
| Author |
[Modern View]
| 53H
10-27-2012 03:46:43
64.111.131.244
My 1940 H has a problem with surging when under no load. It runs fine when put under load. I did some work to the governor a few years back to improve throttle response when I replaced the governor weights and pins as well as the gov. spring. Throttle response is great now but I have the surging problem [which I don"t think I had before]. I have checked the linkage to the gov. as well as the linkage between the gov. and carb., I can"t see any excessive play anywhere. Anyone have any ideas? Thanks |
| Janicholson
10-27-2012 10:46:39
96.24.99.126
Re: Farmall H engine surges in reply to 53H, 10-27-2012 03:46:43
| With the tractor warmed up for 15 minutes or so. set the static timing and make sure the centrifugal advance is allowing full advance at high idle (assumes distributor, not Mag. Mags have no advance)(full throttle no load) Idle it down to slowest idle. Set the idle speed to about 500 or as slow as is reasonable. Adjust the idle mixture screw in and out until the idle is as fast and smooth as possible. Readjust the speed. and repeat the mixture adjustment, finessing it to smooth. if the surging goes away, great! If it does not, it at least sure not the mixture settings or IGN. Internal and external governor settings and surge suppression adjustment should make it correct. Jim |
| The Red
10-27-2012 07:11:52
69.246.205.0
| | Couple of things I have encountered wrenching with Hs for 20 some years. In the governor, check the thruster bearing and make sure it is sliding back and forth horizontally but not wiggling. Had that happen on a 1951H. But it surged whether loaded or not loaded. Other thought is look at the end of the throttle rod on the top of the engine and inspect the control rod swivel assembly on the end. It might be loose or even have a spring missing. Had another H that had that problem. |
| Dean Olson
10-27-2012 07:08:04
98.196.66.64
| | I'm right in the middle of diagnosing this problem with my Super C. From what I've learned from this sight it either comes down to inconsistent fuel flow, loose linkage internally in the governor or externally between the governor and the carb. Assuming the rebuilt governor is working fine and the fact that it only surges under load, I'm betting you have a fuel restriction. Be sure and post back the fix. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
