Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: H just stopped
[Return to Forum]
alderman
10-26-2012 01:24:00
75.104.96.36
I started up my H that I got a couple months ago and was running it at half throttle when it just died. Now I have nothing at the starter. Not a even a groan. Wiring issue? Battey? I'm baffled as usual.
[Reply]   [No Email]
pete 23
10-26-2012 11:41:35
74.32.238.2
 Re: H just stopped in reply to alderman, 10-26-2012 01:24:00
Here is another scenerio ( spelling). Tractor runs for a bit, dies. You hit starter, starter gets stuck, drive to ring gear. So, you loosen starter bolts to allow starter to come loose from flywheel ring gear. Probable reason tractor dies after it had stood for a few days is carburetor float needle stuck so it ran until carb bowl runs dry. To check, take plug out of bottom of carb to check gas flow. If none, tap carb with wood stick, plastic screwdriver handle and see if gas flows. If so, problem solved. If it was not stuck needle, ignore my comments and go with other replys.
[Reply]  [No Email]
old
10-26-2012 09:44:08
209.86.226.58
Well #1 check battery to make sure it is not dead. #2 check battery cable connections. #3 check battery cable connections where they go to ground and where they go to the starter button. #4 use a jumper cable from the battery ignition side right to the starter. BE 1000% sure it is out of gear and see if it will spin over by doing that. If it does then the starter button is bad. If it does not the start is locked up to the flywheel or it is bad or a cable connection is bad. No matter what you should get a few sparks when you use the jumper cable
[Reply]  [No Email]
DeltaRed
10-26-2012 07:03:03
67.6.219.50
Check your coil.My Sh did that.When I rewired it/converted it to 12v,I neglected to replace/add restrictor to the coil.The 12 volts smoked it after a short bit of running.
[Reply]  [No Email]
ken house
10-26-2012 05:17:36
173.242.240.50
farmalls are noted for losing the electrical ground. check and clean ground cable.
[Reply]  [No Email]
mkirsch
10-26-2012 05:15:39
64.80.110.74
You've got a bad battery connection, most likely.
Usually it's either one of the clamps on the battery terminals, or the ground connection.
Rather than just be baffled all the time, try learning about the various systems on the tractor and how they work. That way instead of having to learn each individual problem/solution combination, you can go through each system when you have a problem, and find the problem.
Example: Tractor dies and won't even turn over. Since the starter won't turn you know it's an electrical problem. Where does the power for the starter come from? The battery. Okay, check the battery voltage and the connections on the top of the battery. There are a couple of big fat cables coming off the battery. Follow them, and *check* everything you come across as you follow the cables. (Looking at something does not qualify as checking, usually there is a test you can perform.)
[Reply]  [No Email]
farmallboy15
10-26-2012 04:28:10
64.247.89.145
Once upon a time the battery terminals on my H shorted across the bat box lid and melted a clamp! It just died... I would check connections on battery.
[Reply]  [No Email]
tbish
10-26-2012 02:31:52
50.40.175.66
well with the little info i would try another battery if that starts her id check generator sounds like generator not charging and battery went dead
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
