Yesterday's Tractor Co. Tractor Parts for All Brands
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: six volt starter/ farmall c tractor.
[Return to Forum]
James w. Albright
10-25-2012 14:35:04
24.101.238.50
I had the starter, rebuilt. i installed the starter. but it won!t turn the engine over.
i hooked it up to my truck battery,twelve volt.
the starter turns the engine,when hooked to the twelve volt battery. i also checked the voltage from the battery to the starter. it is getting six volts going into the starter.
[Reply]   [No Email]
gene bender
10-25-2012 17:12:31
207.177.56.85
 Re: six volt starter/ farmall c tractor. in reply to James w. Albright, 10-25-2012 14:35:04
Get new 1ga cables then there is the sw on the starter and it will turn the engine over great
[Reply]  [No Email]
Jim Becker
10-25-2012 16:59:39
173.74.120.222
Quoting Removed, click Modern View to seeHow close to 6 volts do you have at the starter WHILE YOU ARE CRANKING? If it drops too much, you have a bad connection. Measuring 6 volts at the starter when not cranking doesn't mean much.
[Reply]  [No Email]
oldiron29
10-25-2012 15:40:00
74.88.11.200
James, Farmall C and super C Had bad grounding point. Remove the gound cable from the sheetmetal on the steering pedistal and bolt it to the casting with the bolt under the battery box. Good ground and your starter will work fine. oldiron29
[Reply]  [No Email]
old
10-25-2012 15:30:00
209.86.226.57
Clean tight and bright so you have to make sure ALL connections are good plus you have to have the correct size battery cables. A battery cable can also go bad and you can not see when they do and 12 volts can make things work with poor connections or bad cables
[Reply]  [No Email]
david hamblin
10-25-2012 15:15:20
173.215.5.19
you do know it is positve ground
[Reply]  [No Email]
old
10-25-2012 15:28:08
209.86.226.57
 Re: six volt starter/ farmall c tractor. in reply to david hamblin, 10-25-2012 15:15:20
+ or - ground make no difference to a starter it will still spin the same direction not mater which way it is hooked up
[Reply]  [No Email]
david hamblin
10-25-2012 15:11:21
173.215.5.19
do you realize it is positive ground
[Reply]  [No Email]
SDE
10-25-2012 14:49:22
174.124.10.251
Check the battery cable from the battery all the way to the starer. It must be in good shape and without corrosion on the ends. Too much resistance and it will not work. People will tell you to have at least 00 size cable, if I remember correctly.
[Reply]  [No Email]
James w. Albright
10-25-2012 15:19:26
24.101.238.50
 Re: six volt starter/ farmall c tractor. in reply to SDE, 10-25-2012 14:49:22
I checked the cables to the starter. they are good. ichecked them with a meter.
question, if the brass stud inside the starter is not making good contact, with the switch, could that be the problem?
[Reply]  [No Email]
dave bn
10-25-2012 19:36:37
70.194.4.132
 Re: six volt starter/ farmall c tractor. in reply to James w. Albright, 10-25-2012 15:19:26
James, I had the post on top of the starter (under the switch) replaced on my C. Made a big difference. I can sit on my seat now and start the tractor, before I had to stand beside tbe tractor and pull like heck several times to engage the starter. And yes, additional ground from battery to torque tube is a big help.
Dave
[Reply]  [No Email]
John G. Hasler
10-25-2012 17:06:24
174.124.22.175
An ordinary meter will only tell you that they are not completely open. A small fraction of an ohm of resistance is enough to keep the starter from turning. Check the voltage at the starter while it is trying to turn the engine over.
[Reply]  [No Email]
Dave_Id
10-25-2012 14:39:18
107.207.72.252
Does it spin over really fast with the 12 volt battery? Or normal for 12 volt? It's possible the wrong stuff was installed by your rebuilder.
[Reply]  [No Email]
504
10-25-2012 19:45:03
199.127.54.155
 Re: six volt starter/ farmall c tractor. in reply to Dave_Id, 10-25-2012 14:39:18
Like has been mentioned before, the grounds on the C, SC are not very good at the pedestal, and yes you can take the switch off of the starter, and look at the contact, if it is pitted or dirty, polish it with a wire brush or emery cloth. Some rebuilders are just, almost rebuilders, the switch should have been replaced.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
