Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: farmall super H wont start
[Return to Forum]
garson
10-19-2012 16:43:08
68.171.234.130
Bought a super h. Has spark and fuel flow to carb is good gas dripping out bottom of carb after cranking. Took a plug out dry as a bone so I know it isn't getting gas to the cylinders. Just can't figure out why any help would be appreciated. Thanks
[Reply]   [No Email]
Ludwig
10-20-2012 10:21:39
68.162.216.127
 Re: farmall super H wont start in reply to garson, 10-19-2012 16:43:08
Strange nobody else has said it yet, the float is stuck, take a 3# hammer and whack the carb, start it with NO CHOKE.
The guy who says they like choke doesn't know what he's talking about. When its cold I give me Super M half choke until it fires, then no choke and it fires right up. If I choke it any more it'll flood...
[Reply]  [No Email]
garson
10-20-2012 13:15:56
24.57.81.194
 Re: farmall super H wont start in reply to Ludwig, 10-20-2012 10:21:39
problem is the carb is leaking out the neck so its overfilling which means the float isnt stuck. nothings been changed recently. the old guy im buying it from said his son drove it about 3 months ago and parked it it the barn and hasnt run since.
[Reply]  [No Email]
mkirsch
10-20-2012 05:11:02
64.80.110.75
Ok, first off, has anything been changed recently?
They don't suddenly develop a massive vacuum leak overnight unless vandalism is involved, unless you've been working on the tractor.
If gas is dripping out of the carb, then it is flooding. Choke will only make it worse.
[Reply]  [No Email]
El Toro
10-20-2012 04:18:43
108.3.143.30
Hold your hand over the throat of the carburetor and see if there's good suction while a helper makes an attempt to start the engine. Low suction
means you have low intake manifold vacuum. Do the compression check as been mentioned and if it looks good you probably have an intake manifold leak somewhere. Quirt a little starting fluid where the intake mates to your engine while a helper makes an attempt to start the engine. If the engine fires you've probably found the leak. Try tightening the bolts or nuts on the intake manifold if that doesn't help you probably need a new gasket. Hal
[Reply]  [No Email]
gene bender
10-20-2012 02:11:33
207.177.56.85
What reading does the compression check show that would be a first cause if no compression it will never start.
[Reply]  [No Email]
wisbaker
10-19-2012 19:19:41
207.118.181.192
I like the way John B is thinking, you're not drawing the gas into the cylinders. Cracked/broken warped or obstructed intake manifold, bad gasket on the intake manifold, valves to tight or hanging partially open. Maybe try giving it a hit of starting fluid and see if she responds if not I'd try pulling the plugs and put your thumb over each spark plug hole while cranking it over to feel if you have vacuum, maybe even do a compression test.
[Reply]  [No Email]
504
10-19-2012 18:59:18
64.111.61.44
They like choke, pull the rod and start it.
[Reply]  [No Email]
Dean Olson
10-19-2012 21:26:11
98.196.66.64
 Re: farmall super H wont start in reply to 504, 10-19-2012 18:59:18
504, with all due respect, NONE of my Farmalls need any choke at all if run at least once a month.
If they've been sitting longer than that I'll pull the choke for about 1 second. Any longer than that they flood.
I'm in TX so never see any real cold weather. I also keep them well tuned with fresh gas.
I have Farmall's: 53 SC,53SH,54SH,55 200,55 300.
I do have a JD 60 that needs choke till it fires, then leave at half way to keep running till warmed up. It really like it's choke.
I agree with the opinions that there's a vacuum leak.
[Reply]  [No Email]
Janicholson
10-19-2012 18:58:58
96.24.99.126
Assuming the compression is good, put a teaspoon ful of gasoline in each spark plug hole (plugs back in) and staart it. if it continues to run and start Cool. If there is no joy after 10 seconds, there is probably a manifold leak. (some are internal between the Exhaust manifold and intake. Jim
[Reply]  [No Email]
iowa steve
10-19-2012 18:23:43
207.199.217.237
are the valves adjusted correctly,i bought a m awhile back and it was the other way they were open all the time.
[Reply]  [No Email]
John B.
10-19-2012 16:47:17
38.114.64.214
Sounds like the carb is getting gas, but it's not getting into the cylinders. You may have a cracked intake manifold or a vacum leak else where.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
