| Farmall & IHC Tractors Discussion Forum |
Topic: 424 hydraulic fill
[Return to Forum]
| Author |
[Modern View]
| ronnie jenkins
10-19-2012 15:39:34
72.242.37.97
424 1963 drained hydraulic fluid in three drain plugs how many plugs are there to put fluid when refilling and how do bleed system thanx |
| jimb2
10-20-2012 07:00:17
174.114.182.155
Re: 424 hydraulic fill in reply to ronnie jenkins, 10-19-2012 15:39:34
| Hi Ronnie, the 3 plugs in the bottom would have drained the trans/diff and mid section of drive train. Normally those parts are filled with 90wt transmission gear oil unless the tractor was an industrial model and then the trans/diff is used as a hydraulic reservoir and is filled with hytran hydraulic oil. The trans/diff is filled by a plug by the gear shift lever and holds 5 US gal. There is a trans/diff lever check plug on side of trans by the brake pedals. Park the tractor with front wheels lower than rear. Put a bucket on the foot stand by the brake pedals. The hydraulic reservoir is then drained by loosening the clamps on the rubber joining hose on the suction line beside the gear shift and sliding the joiner forward towards the engine and then rotate the section of suction pipe connected to the hydraulic housing so that it will drain into the bucket. After hydraulic fluid is drained, the suction filter can be cleaned by pulling forward on the drain pipe and the filter will come out of hydraulic reservoir. Becareful not to damage "O" ring, put some hytran fluid on "O" ring before re-installing suction filter. The hydraulic reservoir is filled by plug behind the seat by 3pt top link housing. It holds about 3 US gal of hytran. To get the air out of hydraulic system, before tightening the joiner rubber put hytran in the reservoir and let the air bleed out at the joint on the suction line. After reservoir is full, leave filler plug loose and joint tightened then start engine and work 3pt up and and PS left and right until air purge from system . Refill reservoir until hytran is above the shelf when you look in the filler hole. Hope this helps JimB |
| ronnie jenkins
10-20-2012 08:03:24
72.242.37.97
Re: 424 hydraulic fill in reply to jimb2, 10-20-2012 07:00:17
| many thanks mr. jimb2. these directions right to the point and even my simple brain can understand them. have gotten some vague answers to other questions but have confidence in your answer. thank you so much!!!!! |
| jimb2
10-20-2012 14:07:16
174.114.182.155
Re: 424 hydraulic fill in reply to ronnie jenkins, 10-20-2012 08:03:24
| | Hi Ronnie, what type of oil/grease came out of bottom drain plugs? Was it hytran or trans/diff grease? JimB |
| rjcontent@yahoo.com
10-21-2012 10:11:56
72.242.37.97
Re: 424 hydraulic fill in reply to jimb2, 10-20-2012 14:07:16
| thank you much. have anymore questions I hope i can call on you. THANKS |
| ronnie jenkins
10-20-2012 19:50:14
72.242.37.97
| the lubricants in all three drains had the same texture. feels like hydraulic oil is it ok to put hydraulic oil in both ports? the fluids that came out looked like milk. engine oil was normal and radiator has no oil in it. is there something else I should know? THANX |
| jimb2
10-20-2012 20:14:59
174.114.182.155
Re: 424 hydraulic fill in reply to ronnie jenkins, 10-20-2012 19:50:14
| Ronnie, Hytran or equivalent is good for both trans/diff as well as hydraulics. The only problem using Hytran you may get oil seeps out of outer axle bearings, diff lock actuator, pto shaft or into brake housings. BUT if tractor had Hytran in trans/diff without problems then it should be good to go again. The next generation of tractors newer than the 424 had Hytran in the trans/diff as the trans/diff is used as hydraulic resrvior and hydraulic pump(s) are in the trans/diff case. JimB |
| ronnie jenkins
10-20-2012 01:07:47
72.242.37.97
| could someone please tell me where to add hydraulic fluid after draining whole system on 1963 424 IH. I removed three plugs on bottom of tractor to drain system. HELP |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
