Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Janicholson, could use a hand
[Return to Forum]
BigTone
10-19-2012 15:12:04
70.192.11.92
how do you adjust the float? do you bend the tab on the hinge? (Thats what I have been doing) or, The hanger has a hole on the far side, and a hole with a vertical slot on the near side, do I do something with that, the directions in the carb kit were vauge. Is there a measurement when the float is completly open because the 1 5/16" from the top of the cast to the bottem of the floatis there everytime I close the float, I dont see why anyone would need to adjust it. thanks Jim (or anyone else that can help). ~Anthony
[Reply]   [No Email]
pete 23
10-19-2012 18:17:12
74.32.238.2
Re: Janicholson, could use a hand in reply to BigTone, 10-19-2012 15:12:04
Two measurements are 1 5/16th with carb upside down, measured from what is now top of float to the carburetor without gasket. Other is 1 15/16th float drop measured to lowest point of float when turning carb back right side up. The drop is easy to adjust with that little tab on float. Height can be real tricky. I have bent hundreds of those M floats over the years by getting a pliar in the right position so you do not damage float. This is tricky and has to be done with care and diligence. Ideally, if you could find thinner or thicker gasket under needle and seat works the best. Now, keep in mind , that float has to not touch sides of carburetor. Also, the hinge pin has to fit tight in bracket. You bend the split in bracket before inserting pin,use a small screwdriver in that slot when installing pin so pin will slip in but be tight when in place. It sounds to me like you have a needle sticking in the seat. May have to polish edges a little so it moves freely. Needle should drop down with out any persuasion when you invert carburetor back and forth.
  [Reply]  [No Email]
rustyfarmall
10-20-2012 06:57:23
216.248.71.226
Re: Janicholson, could use a hand in reply to pete 23, 10-19-2012 18:17:12
I have mentioned many, many times in many different topics posted by many different folks how to cure that sticking needle issue, and NO, it does NOT need to be polished, or tapped on to seat it. Doing either of those tricks will only cause you to go out and buy another needle and seat.
  [Reply]  [No Email]
pete 23
10-20-2012 10:30:34
74.32.238.2
Re: Janicholson, could use a hand in reply to rustyfarmall, 10-20-2012 06:57:23
I should have said polish the edges of the needle,
not the seat. Done it many times and didn't have to
go out and buy a new seat.
  [Reply]  [No Email]
rustyfarmall
10-20-2012 14:06:38
216.248.71.226
Re: Janicholson, could use a hand in reply to pete 23, 10-20-2012 10:30:34
What you accomplished by polishing the needle was to remove the residue left over from the manufacturing process. A generous dose of carb cleaner will do the same thing.
  [Reply]  [No Email]
pete 23
10-20-2012 18:45:06
74.32.238.2
Re: Janicholson, could use a hand in reply to rustyfarmall, 10-20-2012 14:06:38
Plus a few rough edges.
  [Reply]  [No Email]
rustyfarmall
10-21-2012 06:01:12
216.248.71.226
Re: Janicholson, could use a hand in reply to pete 23, 10-20-2012 18:45:06
I've installed a BUNCH of new needles and seats in the last few years. A BUNCH. I've never encountered any rough edges on any of them.
  [Reply]  [No Email]
pete 23
10-21-2012 11:06:17
74.32.238.2
Re: Janicholson, could use a hand in reply to rustyfarmall, 10-21-2012 06:01:12
I haven't discovered many over the last 55 years
either but it does happen. Just another of those
things you look for when having problems and carb
cleaner in a spray can wasn't even thought of when
I started working on the M carbs. Fact is , didn't
even have the viton tipped needle until in about
1960 for t hose carbs. IH started using them when we
could not keep the 560's from dripping with steel.
  [Reply]  [No Email]
BigTone
10-20-2012 03:04:25
70.192.1.163
Thank you
  [Reply]  [No Email]
BOB HAWBECKER
10-19-2012 15:38:37
71.173.208.237
does your float look like this?
  [Reply]  [No Email]
Janicholson
10-19-2012 18:00:19
96.24.99.126
Re: Janicholson, could use a hand in reply to BOB HAWBECKER, 10-19-2012 15:38:37
Floats have two adjustments. One is the "level" it adjusts the level of fuel in the bowl when the carb is full, and shuts off the flow. this acts like a toilet tank float and when in continuous operation running the tractor, is just part way open allowing just enough fuel in to support the flow into the jets and idle ports.
It is the distance from the float to the carb body. (usually measured with the carb upside down, or with finger pressure and good "feel" with it on the tractor. The second is float drop. most carbs have this adjustment. It stops the float from dangling too far when the fuel stops coming in (out of gas), or the valve is shut off. The purpose is to prevent the float pontoons from touching the bowl (ever). if they touch, they can stick and prevent control, or just wear and eventually get a hole that sinks them. The pontoons must also be adjusted some times to assure they do not scrape on the sides.
Jim
  [Reply]  [No Email]
BigTone
10-20-2012 03:04:59
70.192.1.163
Re: Janicholson, could use a hand in reply to Janicholson, 10-19-2012 18:00:19
Thanks Jim
  [Reply]  [No Email]
BigTone
10-19-2012 16:06:08
70.192.21.190
yes, thats it
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
