Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: M is back firing now, please help
[Return to Forum]
BigTone
10-19-2012 11:26:24
67.248.255.222
took the carb apart again, replaced the gasket, and the motor is now firing, but as it starts it either immediatly dies or as im starting it, it back fires. I'm lost guys, is it getting to much gas? should I reajust the float? I could really use some help, thanks, anthony
[Reply]   [No Email]
JRSutton
10-20-2012 11:13:40
75.130.109.233
 Re: M is back firing now, please help in reply to BigTone, 10-19-2012 11:26:24
something else just occurred to me - a friends M was having a lot of weird carb issues.
Drove me crazy trying to clean it/adjust it. Kept dying under load.
Turns out the metal fuel line was kinked. It LOOKED like it was flowing enough gas - but after I swapped in a new line, it ran like a champ.
Just something else to keep in mind. Sometimes an "ok" flow isn't "ok" enough.
[Reply]  [No Email]
JRSutton
10-20-2012 11:07:38
75.130.109.233
Assuming all else is fine - carbs can be frustrating.
Sometimes you just have to find a very narrow sweet spot for the mixture /idle adjustments.
Do as somebody here pointed out the 1 1/2 turn out or whatever it was as the starting point.
Then make SMALL adjustments from there. Like 1/8 turns.
I've found some carbs you can be within 3 turns of where it wants to be and it'll run fine - others have a very tiny window where the balance has to be just right.
You'll get it.
[Reply]  [No Email]
David G
10-19-2012 19:20:03
205.215.206.18
Make sure you put the venturi back in, btdt. Mine was in the bottom of the washer basket.
[Reply]  [No Email]
John B.
10-19-2012 16:44:35
38.114.64.214
You need four things to make an engine run;
1. Air
2. Fuel
3. Compression
4. Timing
Your timing may be off our you have a leaky intake valve, from being burnt or valve clearance set too close.
[Reply]  [No Email]
wayne in mn
10-19-2012 12:14:22
64.118.12.213
Sounds like a lean fuel mixture. If you use the choke, how does the situation change?
For a starting point, I bottom out the idle AIR screw, then back out 1 1/2 turns.(in is richer-out is leaner)
The main or hi speed FUEL screw is backed out 3 1/2 turns or so. (in is leaner-out is richer)
NOTE THE DIFFERENCE BETWEEN THESE 2 ADJUSTING SCREWS.
The float is set at the factory recommended setting. (don't recall the distance at the moment)
Is there an air leak between the manifold & the cylinder head?
With the spark timed at TDC, the engine should run well enough to make additional adjustments.
Send me an e-mail noting your location.
[Reply]  [No Email]
BigTone
10-19-2012 12:24:20
67.248.255.222
 Re: M is back firing now, please help in reply to wayne in mn, 10-19-2012 12:14:22
I did it all, I think im going to get a new float because I may have messesd that one up. should be no leak at the manifold, brand new manifold and gaskets. its close to timed, I was going to fine adjust it once its running. Gas tank is full of crap from sitting, im draining the gas, replacing the filter. Ill re check those adjustments to make sure. I also had the #2 and #3 plug wires switched so I think that was my problem all along. thanks for the help, anthony
[Reply]  [No Email]
El Toro
10-20-2012 05:56:04
108.3.143.30
 Re: M is back firing now, please help in reply to BigTone, 10-19-2012 12:24:20
Your plug wires should be in this firing order on the cap. Hal
2-1
4-3 As the rotor rotates cw.
[Reply]  [No Email]
hayfarmer
10-19-2012 12:09:56
71.80.194.62
Sounds like a timing issue. If you have had plug wires off you might check that firing order is correct, should be stamped on side of the block.
[Reply]  [No Email]
BigTone
10-19-2012 12:25:14
67.248.255.222
 Re: M is back firing now, please help in reply to hayfarmer, 10-19-2012 12:09:56
I had the #2 and #3 wires switched, im going to do a little maintaince to the fuel system, change the float and try again. thanks for the help. anthony
[Reply]  [No Email]
Zachary Hoyt
10-19-2012 12:30:55
184.12.65.37
 Re: M is back firing now, please help in reply to BigTone, 10-19-2012 12:25:14
Shouldn't need to change the float unless it is dented or has a pinhole leak and is filling up with gas. If it is dented I have heard that you can sometimes pop the dent out by sticking the float in hot water but have not tried that myself. Try shaking the float, if it leaks you will hear the gas slosh in the pontoons. If no dents and no hole I would not buy a new one, ou likely just need to adjust it.
Zach
[Reply]  [No Email]
BigTone
10-19-2012 14:13:27
70.192.10.193
 Re: M is back firing now, please help in reply to Zachary Hoyt, 10-19-2012 12:30:55
how do you adjust the float? do you bend the tab on the hinge? The hanger has a hole on the far side, and a hole with a vertical slot on the near side, do I do something with that, the directions in the carb kit were vauge. thanks
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
