farmall wide front end
susan4856
New User
i would like to know if a farmall m wide front can fit a 300 ih and how much modifications i would have to do it is a SCHWARTZ wide front
It could probably be made to work,but for the amount of fabrication involved,I would think you would be better off to sell that one to someone with an M thru 450 and find yourself one off of an H thru 350 that will just bolt on.
They are STILL pretty easily found.
(quoted from post at 09:06:17 10/19/12) i would like to know if a farmall m wide front can fit a 300 ih and how much modifications i would have to do it is a SCHWARTZ wide front
It will not be a direct fit, but if it is a Schwartz, the correct part to make it a custom fit is readily available.
