| Farmall & IHC Tractors Discussion Forum |
Topic: farmall 400 motor
[Return to Forum]
| Author |
[Modern View]
| alex t
10-18-2012 20:36:28
98.132.231.144
i have a ih 400 block (c264) that i want to put in a farmall m. my plan is to put the 4 1/8 fire crater overbore pistons from hy-capacity in this c264, will a 8060 head off of a farmall m fit or will the pistons hit the head? any advice would be helpful. thanks, alex |
| dblair
10-19-2012 06:33:40
67.172.201.147
Re: farmall 400 motor in reply to alex t, 10-18-2012 20:36:28
| the lp head on ebay is great the heads you mention are good heads for older tractors but not for getting much hp out of the 264 block made into a 281. a 362174 gas head is good . you will be able to run any of the pistons you mentioned with any of the heads including the lp head
This post was edited by Dblair at 07:04:48 10/19/12. |
| D Slater
10-19-2012 05:59:07
184.15.8.46
| See they list 2 pistons. Don't know if they are the same piston shape on the top or different. When IH made them the 374456 (memory may be a little off on the piston #) number, it was recommended for engines with a 8060 or 8574 head and the other number for engines with the 400 gas head. They were differently shaped. Since the 400 engine used two different connecting rods and piston pin sizes it may affect what piston set you use. If you have small pin rods the big pin pistons won't fit. If its the big pin rod, adapter pin bushings can be used to change the size. Probably can get more power from a specialty aftermarket piston with those heads. Depends on what grade of gas you want to run. You didn't say what suffix was on the 8060 head. |
| The tractor vet
10-18-2012 22:12:05
75.24.0.62
| No with that head you can run the above 8500 ft pistons and have lot of room to spare. You can even run a stock 450 gas head and be fine . BTDT. |
| sflem849
10-19-2012 05:00:40
69.197.84.39
Re: farmall 400 motor in reply to The tractor vet, 10-18-2012 22:12:05
| Quoting Removed, click Modern View to see
So you can or can't? I don't understand your sentance.
So what would the best head for that setup be? 8060, 450, or ??? |
| The tractor vet
10-19-2012 06:42:17
75.24.0.62
Re: farmall 400 motor in reply to sflem849, 10-19-2012 05:00:40
| The best would be the 450 head . But with the high alt. pistons it will work on any head BUT not the propane . |
| Janicholson
10-18-2012 21:28:39
96.24.99.126
| Put them in, and set the crank so that #1 is almost up. Put a used head gasket on the block, turn the head over and put oil based modeling clay on the edges of the combustion chamber, but wthin the area of the gasket. Set the head in place and put the head bolts in but leave them 1/8 inch loose. Turn the fan by hand, or crank, or raise one wheel and put it in fifth. This allows the engine to be turnd carefully through one revolution. If the piton raises the head, stop. if not they will deform the clay such that you will be able to see the clearance where the head comes close to the popup. Usually .060", to.080" is plenty. Jim |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
