| Author |
[Modern View]
| Zachary Hoyt
10-18-2012 05:24:11
74.47.56.14
I was looking at craigslist and saw this M with what looks like maybe a hydraulic reservoir on the front. I never saw one like that before. I am thinking about whether it would make sense to buy it, sell the PS and WF and then figure out what to do with the rest of it. I have never dealt with either of those parts before and am not sure what to look for other than general leaks/looseness. Zach |
[Reply] [No Email] | |
| TomH in Pa
10-18-2012 16:45:39
67.235.10.94
Re: Anyone seen one of these on an M? in reply to Zachary Hoyt, 10-18-2012 05:24:11
| Something is wrong with the rear tire too. I'd assume parts tractor, and probably mostly broken parts. Sitting out in the open with no muffler? I doubt it "starts and runs" and would be surprised if the engine is free. |
| 460anger
10-18-2012 16:02:35
65.110.104.48
| check out the gas tank. If you buy it I have a narrow front for it and one of thos 31 loaders you like even comes with the factory spacer blocks for your 300 |
| Fixerupper
10-18-2012 15:36:10
100.42.82.164
| If the front wheel is broken off and he can't drive it how does he know the tranny's OK? If it starts right up I would think the engine should be free? Jim |
| d beatty
10-18-2012 06:13:47
24.12.128.253
| Myy dad built a Loader on our Farmall B back in the early 60's and used a tank like that for hydraulic reservoir. He bought ours from Tractor Supply. |
| tractor300
10-18-2012 06:11:54
173.84.222.152
| Runs great, starts right up, motor free, will 'push' on trailer. Hmmmm. |
| mkirsch
10-18-2012 09:36:54
64.80.110.74
Re: Anyone seen one of these on an M? in reply to tractor300, 10-18-2012 06:11:54
| Quoting Removed, click Modern View to see
For $875 what do you want? |
| 1960s
10-18-2012 06:03:02
99.196.224.56
| The tank on the front looks like a reservoir tank off of a New Holland swather. I have an M that someone put one on the front. those tanks were not available stock that was something someone added. don"t know if you should buy it though because of the way the right front wheel looks. |
| rustyfarmall
10-18-2012 05:53:04
216.248.71.226
| Is that tiny picture intentional? It's so small I can't even guess what it is. |
| GordoSD
10-18-2012 07:10:24
64.33.250.162
Re: Anyone seen one of these on an M? in reply to rustyfarmall, 10-18-2012 05:53:04
| Hold the ctrl key down and use the mouse wheel to blow it up |
| Harold H
10-18-2012 07:47:48
12.23.230.67
Re: Anyone seen one of these on an M? in reply to GordoSD, 10-18-2012 07:10:24
| | Thaqt doesn"t work on mine. Harold H |
