Yesterday's Tractor Co. Trusted Parts Supplier since 1995
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: timing
[Return to Forum]
John in Pennsylvania
10-14-2012 08:51:11
174.238.136.68
The follow up to my original posting yesterday. I have
removed the front cover exposing the injection pump gear to
check the timing works. They are not even close. I rotated
engine by hand multiple times to see if they would line up
they do not. But the tractor will start just smoking badly. Am
I missing something here with the timing marks???? The next
reply posting to mine has a picture of what I'm looking at.
[Reply]   [No Email]
jimb2
10-14-2012 10:27:07
99.241.38.122
Re: timing in reply to John in Pennsylvania, 10-14-2012 08:51:11
Hi John, we bought a B414D with BD-154, new in May of 1962 and in August while baling with it, the engine sort of back fired thru the air cleaner and stopped and would not start again. Fortunately it was still under warranty and IH took it back to the shop and found engine had been put together without key in camshaft gear causing valves to become out of time with crankshaft. IH replaced pistons, rods, valves and push rods.
In your case, I don't believe pump and engine are much out of time or it would be very difficult to start. The good thing about BD-154 is it has glow plugs, so you can remove glow plug from #1 cylinder and determine compression stroke on #1 and valve closing timing. Probably you can do the soda straw thru the glow plug hole to determine TDC for #1.
I still believe the smoking problem is a too much fuel being delivered to the cylinders. You are certain the fuel return is working properly from the injectors and the pump?
JimB
  [Reply]  [No Email]
10-14-2012 10:37:36
174.231.18.104
Re: timing in reply to jimb2, 10-14-2012 10:27:07
You can see the fuel squirting into the fuel tank while the engine is running. I cracked the return line on the pump and fuel flows out of it profusely. Anything else you think I should take a look at before I pull the injectors and pump? I have an extra cav pump that i bought off ebay for 10 dollars. I got it just for parts. I opened it up and looked inside.... there's a lot of stuff in there
  [Reply]  [No Email]
jimb2
10-14-2012 13:40:54
99.241.38.122
Re: timing in reply to John in Pennsylvania, 10-14-2012 10:37:36
Hi John,
DO THIS AT YOUR OWN RISK,
Neighbour had a MF135 same CAV pump as BD-154 and it would not start. Neighbor was retired farmer and only used MF135 to plow garden and snow in winter, rest of the time it was in the garage.
MF mechanic came out and gave the pump a good rap with a hammer on the end of the pump were the inlet pipe is. Tractor started and it is still running today as my cousin bought it at neighbour's estate sale. Mechanic said metering valve likes to stick when tractor is not run very often.
JimB
  [Reply]  [No Email]
10-14-2012 14:48:34
70.199.108.0
Re: timing in reply to jimb2, 10-14-2012 13:40:54
Being aluminum cap I'm not going to hit on it with a hammer. But it's funny you say that the old injection pump I bought for parts the metering valve is stuck in it is well. I will open the top of the pump and look inside and take a look I've already opened the side cover..... everything seems okay there
  [Reply]  [No Email]
10-14-2012 16:28:02
174.252.217.199
Re: timing in reply to John in Pennsylvania, 10-14-2012 14:48:34
Opened the cover.....all looks good
  [Reply]  [No Email]
The tractor vet
10-14-2012 09:06:32
75.24.0.62
I am not the real expert on the 154's but i do know this that the only time that you get all the timing marks lined up is when you first put the engine together . after that it is hit and miss.
  [Reply]  [No Email]
10-14-2012 09:23:21
70.194.2.190
Re: timing in reply to The tractor vet, 10-14-2012 09:06:32
That sounds like a great design NOT.... So it's not me I thought I was losing my mind...lol
  [Reply]  [No Email]
10-14-2012 09:01:02
174.238.136.68
It's an international 364 with a bd 154 engine..... sorry I can't figure out how to attach a photo
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
