| Farmall & IHC Tractors Discussion Forum |
Topic: Charging
[Return to Forum]
| Author |
[Modern View]
| KTNC
10-13-2012 17:57:46
75.194.50.226
I just replaced a battery on my M which is converted to 12V. It starts fine, but I am wondering should the voltage guage by light switch show that it is charging (point to right)when running? It does do that when I turn the lights on. When running with no lights, it remains in the middle... Is this right?Thanks |
| Owen Aaland
10-15-2012 16:03:29
216.47.35.76
Re: Charging in reply to KTNC, 10-13-2012 17:57:46
| The gauge will read the same whether it is used with six volts or twelve volts. Most likely when the tractor was switched to twelve volts it was also switched to negative ground instead of the original positive ground. If the wire on the back of the ammeter are not switched when the ground is switched the gauge will read backwards. |
| KTNC
10-15-2012 08:38:23
75.213.220.105
| It's an amp meter, looks like the original. When I turn on the lights with engine off, it goes to the right. Same place it goes when engine running and I turn the lights on. I'm thinking guage is hooked up wrong, maybe when it was converted to 12V..?? BTW should the guage still function the same as when it was on 6V? Battery is brand new... |
| mkirsch
10-14-2012 08:37:40
67.253.161.186
| Is it a VOLT meter or an AMP meter?
What does the face of the gauge say?
Farmall M's came from the factory with an AMP meter, but that could have been changed to a VOLT meter.
An AMP meter would stay in the middle only if the tractor is off. When you turn on the ignition and/or lights with the engine off, the needle should move to the left. When you start the engine, the needle should move to the right. |
| John G. Hasler
10-14-2012 05:40:00
174.124.54.72
| If the ammeter swings to the right and stays there when you turn the lights on you have a wiring error. |
| soundguy
10-13-2012 18:11:13
107.41.227.231
| does it have a tickle resistor for the genny for when the lamps are on? |
| Janicholson
10-13-2012 18:09:11
96.24.99.126
| With respect, that is an amp gauge measuring electrical flow, not pressure (voltage). if it is an alternator that is a perfect reading for a charged battery. When the battery is fully charged, the system's voltage regulator allows the charge rate to prevent over charging. A generator system is less likely to do such a good job, but it is supposed to. when running at 3/4 throttle it should read 14.2 volts measured across the battery. (a needle type meter is best for this reading) Jim |
| KTNC
10-14-2012 07:55:23
74.82.64.160
Re: Charging in reply to Janicholson, 10-13-2012 18:09:11
| So it should stay in the middle all the time, lights on or off? |
| John G. Hasler
10-14-2012 08:36:39
174.124.54.72
Re: Charging in reply to KTNC, 10-14-2012 07:55:23
| If you turn the lights on with the engine stopped the ammeter needle should swing left, showing that the battery is discharging. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
